Quantcast is high flow the way to go?? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > is high flow the way to go??
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 10-13-2008, 08:53 PM   #1
jackdup
is having a real high flow 4.0 really as good as you would think..my plans are a dynomax full mandrel bent system with a super tubo muffler..a header..and a magnaflow high flow cat...rusty intake..throttle body spacer...99+ intake manifold and DIY bored throttle body..now..will my low end torque suck? it would make sence to get better mpg, throttle responce, and hp and wide open throttle...but will my low end be lacking..worse than stock? thanks alot..i need this stuff clarified before i take action
jackdup is offline   Reply With Quote
Old 10-13-2008, 09:07 PM   #2
Bugboy
1987 XJ Cherokee
You will probably get more power at higher rpms but lose a bit at the lower end of the scale. I am not sure how much it would be considering the 4.0 is pretty torqy to begin with. so probably wont be too bad.
Bugboy is offline   Reply With Quote
Old 10-13-2008, 09:21 PM   #3
SoloCamo
1988 MJ Comanche
Your power/torque will be made at slightly higher RPM's but the increased flow will easily justify it with the power difference. You will still be making plenty down low
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline   Reply With Quote
Old 10-13-2008, 09:37 PM   #4
jackdup
alright cool...yeah i never thought that when wheeling if i need some more torque i can just punch it..haha...plus it should make passing on the highway alittle easier and the gas back and forth to schoo alittle better
Old 10-13-2008, 09:46 PM   #5
DeepJeep
I personally wouldn't bother with the throttle body spacer.
DeepJeep is offline   Reply With Quote
Old 10-13-2008, 09:48 PM   #6
Saudade
1988 XJ Cherokee
The TB spacer doesn't do squat for a MPI.
Saudade is offline   Reply With Quote
Old 10-13-2008, 09:49 PM   #7
Bugboy
1987 XJ Cherokee
Nice thought! you will be punching it to hear the sound and feel the pickup. but in theory it should be better! hell i would do the same thing!
Old 10-13-2008, 09:55 PM   #8
ehall
1991 XJ Cherokee
Flow is the way to go but don't think that bigger parts=better flow because that isn't how it works. Borla has the highest flow of all and they use relatively small pipes.
ehall is offline   Reply With Quote
Old 10-13-2008, 10:05 PM   #9
Bugboy
1987 XJ Cherokee
yep it gets quite interesting if you really get into it. I used to port heads and make exhausts etc. there are alot of factors but it isnt a drag car so anything over stock should be better unless it is too big for the valve combination, intake etc. does anyone make a tuneable exhaust like the old supertraps for the XJ?
Old 10-13-2008, 10:07 PM   #10
jackdup
well as i would like to realisticly i cant spend 2000 on a full borla system...i already have the spacer so ill just leave it...i got it before i was on the forum much to learn it was crap..but oh well..cant hurt...i dont see how you can get much better flow then dynomax's full mandrel bent system including a down pipe...and most headers look the same with some acceptions..some are just better quality..so that only leaves the cat and muff to restric..cant get much better than the magnaflow high flow..and ive heard the dynomax super turbo flows real good also..so i think it all sounds good
Old 10-13-2008, 10:21 PM   #11
Bugboy
1987 XJ Cherokee
to be honest it depends on the inside of the header not the outside. how the welds are if they are flow ported etc. but you will see a noticable improvement over stock. basically the standard 4.0 header is a 6 into 1 setup best flow would be achieved by setting the firing order to the exhaust and position them into a scavaging type header but then you are talking BIG $$$. for what most of us do you will be well ahead.
Old 10-13-2008, 10:44 PM   #12
jackdup
oh i have one more question..after upgrades like this..you should reset the computer correct? what is the best way to do this...ive read a few methods
Old 10-13-2008, 11:04 PM   #13
ep191
im pretty sure you disconnect the battery for a while, not sure how long
ep191 is offline   Reply With Quote
Old 10-13-2008, 11:10 PM   #14
88cherokeexj
1988 XJ Cherokee
one of my mechanic friends said to completely reset the pcm you need to disconnect both battery terminals then short out the cable ends. this drains any voltage left in the pcm and completely clears any memory it had before
88cherokeexj is offline   Reply With Quote
Old 10-14-2008, 12:13 AM   #15
ehall
1991 XJ Cherokee
My Cadillac FSM says to touch the positive battery wire to the body for a few seconds, which is the same basic effect.
Glock Forum
