Hesitation with low fuel - JeepForum.com
post #1 of 6 Old 09-28-2012, 09:19 PM Thread Starter
matt62
I have a 98 cherokee 4.0. I've had some hesitation with the engine cutting out upon acceleration, especially with the shift from first to second gear, when my fuel is low. I also have the engine cutting out when I corner, or when I go around a pretty sharp curve. This is all with low fuel. It doesn't have to be quite as low When I'm cornering. I'm assuming this is some kind of fuel filter issue? I put a couple bottles of heat in, and it didn't seem to do make a difference. Any ideas?
matt62 is offline
post #2 of 6 Old 09-29-2012, 06:11 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check for wire harness issues under the hood and at the fuel pump. Test the fuel pressure. You should have 49 +/- 5 psi of fuel pressure.
It is possible that you have a fuel pump issue such as a loose or clogged filter or a dislodged fuel pick up.
CJ7-Tim is offline
post #3 of 6 Old 09-29-2012, 08:38 AM
Saudade
1988 XJ Cherokee
How low is "low"?
Saudade is offline
post #4 of 6 Old 09-29-2012, 08:48 AM Thread Starter
matt62
Pretty low. For the cornering thing below an 1/8, for the acceleration thing, just above the E-line. Maybe a gallon and a half or 2 of fuel. Is when it starts. I was thinking sediment or fuel filter, but I wanted to see if there was some other idea before I pull the tank.
matt62 is offline
post #5 of 6 Old 09-29-2012, 02:52 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
You are probably going to end up pulling the tank. And if you do this, I'd have a fresh fuel pump assembly ready to install. My favorite is Bosch, followed by Carter. You get what you pay for with fuel pump assemblies. Do not buy an "el-cheapo" or a "no-name" unit and do not buy an Airtex. That is unless you like doing things twice....
BTW, not a good idea in my opinion to run your gas tank that low. Both for picking up sediment and cooling. Fuel is what cools your fuel pump. As a matter of course, I don't go below 1/8th of a tank before refilling.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 6 Old 09-29-2012, 07:34 PM Thread Starter
matt62
Thanks. I usually fill whenever I get remotely low, but twice I haven't. But on cornering, it doesn't have to be super low. That's the weird thing
matt62 is offline
