Quantcast Herculining Floors - **Write-up** - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Herculining Floors - **Write-up**
Old 07-17-2009, 05:46 PM   #91
MGrobe
Man In Black
MGrobe's Avatar
Originally Posted by douya369 View Post
Since this has already been majorly bumped, I'll say now that when I took my XJ to midway auto to have them look at my floor rust, I asked about herculiner. They told me rhinoliner was better, (i have never compared so im just saying what he told me) and that putting mats or carpet back on top of it will do bad things. Condensation between the mat/carpet and the herculiner/rhinoliner will cause it to peel away from the floor. That, theoretically, can allow condensation to build between the herculiner/rhinoliner and the floor, causing more rust issues that can only be fixed by pulling up the herculiner/rhinoliner. Doesn't seem like a fun thing to do.
Rhinoliner would be better than Herculiner since it is a professionally applied product like the Line-X I have. It's been a solid 6+ years since I had my interior sprayed and ever since I have had carpet directly on top of it and the rubber floor mats on top of the carpet. None of what the midway auto guy warned you about has happened on the interior of my XJ. Once again it probably is more of a case of who did the prep work and how good of a job they did. Perhaps it is more of an issue with the DIY. Like I mentioned in a post last year, you need to make sure that all the pin holes are sealed when using the DIY product. So perhaps water/condensation are getting through that way...
Another DIY product that might be worth looking into that may be a good compromise between Herculiner and a professional product is Second Skin.
http://www.secondskinaudio.com/
Do a search here and at google as I know of at least 6 vehicles that have tried it.
-Marc-
Sweet Pea 1998 - XJ
http://www.grobe.us/Jeep
- JeepForum Rules - Become a Premium Member or Vendor
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is online now   Reply With Quote
Old 07-18-2009, 08:12 AM   #92
bmyohn
Youngin'
bmyohn's Avatar
Originally Posted by 4wheeler4LIFE View Post
REVIVING! haha
after 2 years, how's it holdin up?
after 2 years its been great (wow, two years since ive done this writeup, ugh lol). but the trunk and the rear seats have held up perfectly. i do need to touch up the front driver side area a tad. its starting to peel from the salt and mud and boots.
but the best part of this whole project were the drain plugs, they come in extremly useful. ive been wheelin quite a few times and swamped the jeep. ive sat there and watched my buddies using cups to get the mud out. i just grab the plug and all the waters out within two minutes. so the drain plugs are extremely useful
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 07-18-2009, 01:10 PM   #93
4wheeler4LIFE
so if you had to do it all over again, would use use the same stuff again? or a different product?
4wheeler4LIFE is offline   Reply With Quote
Old 07-19-2009, 10:31 PM   #94
bmyohn
Youngin'
bmyohn's Avatar
same stuff, with the abuse ive shown it its held up remarkably well. i can touch it up here or there with the little quater gallon cans of herc and have it as good as new. so id probably use the same stuff
"The Tow Rig"
1988 Jeep Comanche
Old 07-19-2009, 10:52 PM   #95
CharlieMopps
1989 XJ Cherokee
The only thing I dont like about it is that the inside of your jeep smells like it forever.
1 tip, I did mine in the cold. It took almost 3 days to dry. Keep that in mind. It says 24hrs... but the cold really slows the drying.
CharlieMopps is offline   Reply With Quote
Glock Forum
