#1 | |
Youngin'
Herculining Floors - **Write-up**
As many of you have heard I am Herculining the interior of my XJ and I promised a write-up…so here it is
Its my first write-up so bare with me…lol 1. Tools Needed a. Herculiner Kit i. Gallon Paint ii. Bristle Pad iii. Brush iv. Rollers (not completely necessary) b. Basic Wrench/Ratchet Kit c. Screwdrivers d. Acetone e. Rags f. 1-1/8" Hole saw and 3/8" Drill Bit ![]() 2. Begin by removing the seats 3. Remove the rear seats using a 16mm ratchet to remove the back of the rear seats, there is one on each side. 4. The front seats each have four bolts. The fronts of the brackets have two 13mm bolts. ![]() The rears of the brackets have two different style bolts. The outsides have bolts that are removed with a 13mm bolt, mine were pretty tough to get out. (they are easiest removed with the seat pushed as far forward as possible) The insides of the brackets are nuts that are removed with a 11/16” ratchet. ![]() ![]() (don’t mind the trash…lol) 5. Next, you can remove the seat belts, I chose not to. They are removed with a Torx Head 6. ![]() 7. Once all the seats are removed you can take out the center console, to remove that you must take out the plates at the bottoms of the shifters and unscrew the 6 screws that are there. 8. Pull out all carpet (trunk and front section pulls out in two sections 9. Next, you must remove the sound deadener material (silver metal). The sound deadener is located under the bench seats, on the ground infront of the bench seats and buckets as well as on the tranny hump (I didn’t remove the tranny hump material) ![]() ![]() ![]() I found that the herculiner went over the rubbery/glue type stuff fairly well and it wasn’t worth spending the time getting all of it out. The herculiner doesn’t apply well to the metal though.
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#2 |
Youngin'
10. I also drilled some holes to use as drains, I took two of the drain plugs from the trunk and used them for the front. I took a 1 – 1/8” hole saw to fit the plug
![]() Finished product: ![]() I also added some to under the bench seats using a 3/8” bit There are also these drains that came stock, they get pulled out with a flat head screwdriver pretty easily ![]() The trim can be removed as well at this time. 11. Once vacummed and cleaned out I went around with the bristle pad that came with the kit and scratched the surface, make sure to take care of any rust issues at this point. ![]() 12. Apply Acetone to the surface to clean all the shavings up. 13. Apply a coat of herculiner to the entire floor. 14. While still tacky go ahead and apply a second coat to the floors, I did three coats total (maybe a little overkill, but better safe then sorry) ![]() ![]() ![]() 15. Reinstall all trim and seats, the center console should go on first and then trim and then seats. Finished Product ![]() ![]() ![]()
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering Last edited by bmyohn; 09-30-2007 at 05:45 PM.. |
#3 |
Nice job, thanks for taking the time to create and share that with us!
#4 |
Youngin'
no problem, it was a fun project and messy..lol
now updated with finished pics
#5 |
sexy........so in all how much did it cost?
i can't wait to get mine back shes getting lots of new toys when she gets home |
#6 |
Youngin'
it was 90 bucks for the kit, and about 45 for the hole saw, bit, and acetone
so about 135 or so, but i did find 10 bucks worh of change in the carpets and cupholders...lol what are u planning for urs??
#7 |
shes getting herc'd inside.......from top to bottom lol
found the shifter only center console.....puttin that in doing a complete rewire of a few thing on the inside and some other goodies |
#8 |
opps double post
#9 |
Nice job Brendan, now you can go all the way through nic's pond without worrying lol.
-Brian |
#10 |
Looks great! $45 for a hole saw? O_o
#11 |
Youngin'
no for a hole saw, drill bit and acetone all together
#12 |
nice job looks good i just hurculined the exterior of my jeep today and started ripping out the carpet to do the interior
2001 Grand Cherokee Limited 4.7L 2.5" 40 Series FlowMaster, 245/70/17 Maxxis Big Horns, 2" BB with Black Diamond Shocks, Tow Hook, Hella 500ff. |
#13 |
Looks good Brendan!
Sorry it took me so long, but got back to your PM on GLXJ. |
#14 |
any idea how much hurc you used, i still have atleast 3/4 of a gallon that will prob get it done right?
#15 |
The Guru of Nothing
nice work bmyohn, i hope to be doing this next summer but i have a ton of other things to take care of first
![]() -Kyle BTW good writeup
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
