Herculine adhear to POR 15 - JeepForum.com
post #1 of 10 Old 11-22-2007, 06:38 PM Thread Starter
Topgun514
1988 XJ Cherokee
I want to fix interior rust, and POR 15 everything then herculine...or do i just POR 15 ONLY bad rust sections?
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #2 of 10 Old 11-22-2007, 06:52 PM
hermantherugger
hermantherugger's Avatar
I didn't have a ton of luck w/ the POR 15...if you use it, make sure to follow the directions "to a T". I'm guessing I didn't give it long enough to dry after cleaning it w/ the marine clean or something...but I've got a few spots of rust that wont stop bleeding through my bedliner.
'97 Sahara - 8.8 Swap w/ Artec Truss, UCF Tummy Tuck, ZJ V8 Coils & some spacers, 35" Mud Kings, Rokmen Corners, & 2 car seats :)
'93 Wrangler - 2" BDS Springs, MORE Shackles & Body Lift - Sold
'99 Cherokee Sport - 2" OME springs, Trimmed Fenders, Custom Bumpers - Sold
hermantherugger is offline
post #3 of 10 Old 11-22-2007, 07:36 PM
inmymindithink
1994 XJ Cherokee
well ive heard nothing but good things about por 15, if you get both the liquids to prep like they suggest..and then prime it with good primer
and of course you gotta wire brush or sand blast the rust off, if you sand blast it make sure you put the marine clean and por 15 and all that stuff right after you sand blast, cause if anything touches the bare metal after sandblast it is rediculously easy to get rusted again..so i say once you have a off wake up early and do it all...thats what im doing now
inmymindithink is offline
post #4 of 10 Old 11-22-2007, 07:37 PM
inmymindithink
1994 XJ Cherokee
what exactly are the steps you used hermantherugger?
post #5 of 10 Old 11-22-2007, 07:53 PM
jaburk
jaburk's Avatar
POR-15 actually works best when applied directly to rust. I have also applied it to bare metal that was production #60 sanded and etched with POR-15 metal ready. POR-15 is incredibly tough.
1998 XJ, RE 3.5" Lift
jaburk is offline
post #6 of 10 Old 11-22-2007, 09:52 PM
hermantherugger
I sanded w/ 60 grit, then used the marine clean & metal ready. They require some water rinsing, and I'm not sure if I left the surface a little too damp or it was too humid when I applied it. I have spots of it here and there that are coming off in flakes, so I'm not sure about the whole thing. There's a note about if a drop of sweat gets in a gallon of the stuff it's ruined, so I'm guessing it's pretty finicky to apply.
post #7 of 10 Old 11-22-2007, 10:31 PM
wbacon
1988 XJ Cherokee
Por-15 is for rust only, it will flake off if you use it over painted surfaces. Do not use it over primer either. Use Por-15 first then use chassiscoat over the Por-15, Chassiscoat is for painted surfaces also. I used them both they are great products if used correctly.Don't get any on your skin it will take 2-3 weeks to wear off.
1988 Cherokee 2Dr, 4WD, 4.0 LTR
wbacon is offline
post #8 of 10 Old 11-24-2007, 01:39 PM Thread Starter
Topgun514
1988 XJ Cherokee
I heard that if i take the paint off/ etch it and such with sand paper, that it will hold or even if i put it straight on a slightly rusty surface.
I was thinking about just POR 15-ing my entire tub instead of herculine now because its chip resistant and strong
96 XJ Sport- Sold
post #9 of 10 Old 11-25-2007, 10:23 AM
inmymindithink
1994 XJ Cherokee
well you cant put it on painted surfaces like they said..but if it just bare metal you can, you just have to follow the directions so carefully
post #10 of 10 Old 11-25-2007, 10:44 AM
wbacon
1988 XJ Cherokee
I would use por 15 on the rust, chassiscoat on everything else. Then herc it all....
wbacon is offline
herculine advice! stiffy725 XJ Cherokee Technical Forum 13 10-14-2008 06:11 PM
herculine instead of headliner toates89 XJ Cherokee Technical Forum 11 12-16-2007 11:24 PM
Herculine ? firstjeep11 XJ Cherokee Technical Forum 5 06-20-2007 03:24 PM
people with herculine nudosimmons XJ Cherokee Technical Forum 11 03-04-2007 08:35 PM
Anyone ever herculine the inside of an XJ? bigAL97TJ XJ Cherokee Technical Forum 9 01-30-2004 05:09 PM
