Quantcast HELP!! the XJ might be dead - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > HELP!! the XJ might be dead
Old 10-22-2004, 08:28 PM   #1
LoungeLizard
I was offroading with a friend and we come across this big mud hole that we have to cross to compleate the trail. He goes through first and comes out with quite a bit of struggle. I go next. The muddy water goes about to the fenders and I stop. Water starts coming in, and before I know it, its full of mud. Great. He pulls me out and we pop the hood. We take off the intake cover and the bottom of the box has a little water in it, the filter is pretty wet, and there is a little water in the intake pipe. We feel the throttle body and it seems mostly dry, so hopefully too much water didnt get in. We go to start it and get ::click::., try again ::click::. We hook up the jumper cabels and still get ::click::. Is it just the alternator? Do I just need to dry it out, or am I screwed? HELP!!
98 Cherokee Sport- RE 3.5" Lift, Trac-Lock LSD, Mopar front skid, Mopar T-Case skid, C4x4 Hooks, 31x10.5R15 Firestone MT's, AR 767 wheels
LoungeLizard is offline   Reply With Quote
Old 10-22-2004, 08:45 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
So the engine won't turn over even with jumper cables on it? Make sure to PULL THE PLUGS and turn the engine over to force out any water in the cylinders.
Check and make sure the alt isn't caked with mud.
Let the starter dry out a little and try it then.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 10-22-2004, 08:57 PM   #3
gumby
answer
ck the tire pressure in the left rear tire. It is possable that the conuxer valve is stuck. if not it might be the warp core so jettesion it before the core explodes
write a check to the "I drive jeeps offroad club" and get er done
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline   Reply With Quote
Old 10-22-2004, 08:58 PM   #4
cazs_98
been there
Same thing happened to me. I let it sit for about an hour and a half and it started up. My lights still worked but just didnt' have enough "juice" to turn over. I ended up having to replace the TPS but she runs fine now.
Good luck.
'00 XJ Sport --One ton on 39's --
"Haven't heard that noise before! Time to upgrade the stereo!!"
cazs_98 is offline   Reply With Quote
Old 10-22-2004, 09:05 PM   #5
LoungeLizard
Well, I am letting her sit overnight, so we will see what happens.
Old 10-22-2004, 11:50 PM   #6
xjj33p3r
word of advice, muddin will screw up your jeep. it's not worth the pain/suffering/money
xjj33p3r is offline   Reply With Quote
Old 10-23-2004, 01:13 AM   #7
Blake
Redefining body roll
Blake's Avatar
Wont start? There is water in your distributor. Happened to me a few times. Just pull the cap off, clean it out, shoot some WD-40 in it, wait a few minutes, and you are good to go.
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Old 10-23-2004, 10:05 AM   #8
helix
i had the SAME problem. what you need to do is replace the starter. Somtimes water can get into it and it -=-=-=-=-=-=-=-=s it up bad.
[COLOR=Red]Red[/COLOR] 1996 XJ Sport
4 Door, 4x4, 4.0 HO, Automatic Transmission
CD/MP3 Player - Sony Xplod 5.25" speakers
Rusty's 3" Full springs kit - 5" actual lift
JKS Quicker Disconnects
CB Radio + 4' Whip mag mount + Fully functional PA system
Yakima Load Warrior Safari Rack
30x9.5 kuhmo MT on 15x8 Soft8s with 4.75" backspacing
Rustys adjustable lowers.
helix is offline   Reply With Quote
Glock Forum
