help with XJ lift and other adds - JeepForum.com
post #1 of 24 Old 02-22-2011, 06:28 PM Thread Starter
XJforlife
Im relatively new to the jeep scene. I own an XJ classic 4X4 automatic with the 4.0L and all the mechanical parts are stock (save the air filter). I wanna build it up and lift it to be a long distance driver that has some lift and aggression to it. Im a student at the ohio state university but I live in Alabama so I drive about 700 miles one way, so I wanna maintain road drivability while also having some bigger tires and a better trail stance and get a feel for everything i need to buy and change. Anyone got any ideas?
XJforlife is offline
post #2 of 24 Old 02-22-2011, 06:37 PM
motorheadmach1
1990 XJ Cherokee
what do you plan on using the jeep for when your not on the road? mud,rocks,dirt roads etc.... i guess really it depends on how much money you want to spend. I would say if you lift it more than about 3" you have to start replacing alot more. ive had a daily driver forever thats 3" lift and 31" all terrain tires and its great.
1990 XJ, complete HO swap, approx 4" lift, 33 mt's, "trimmed" fenders, cobra CB, Homebrew roof light bar, 91' non disconnect front axle. various odds and ends.
"Friends don't let friends wrench alone"
motorheadmach1 is offline
post #3 of 24 Old 02-22-2011, 06:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would either go with a 2" budget boost and 30x9.50 tires, or a 3" lift and 31" tires in your situation. The 30's would be more fuel mileage friendly though. With 31's and stock gears you can look forward to 15 miles per gallon or less.
xjfever is offline
post #4 of 24 Old 02-22-2011, 06:41 PM Thread Starter
XJforlife
Im looking to use it on snow, mud and gravel. Mainly for mild trailing when not on the road. I was thinking 3" but I dont know which one or what all I need to change to do a 3".
post #5 of 24 Old 02-22-2011, 06:42 PM Thread Starter
XJforlife
any way to combat the mileage lost with 31s?
post #6 of 24 Old 02-22-2011, 06:47 PM
Kitchen
get an high flow exhaust setup, with a cold air intake?
- 99 XJ
5 inchs on 33 kevlars
Locked F&R, bumper, winch, etc...
Build thread:
- 03 TJ Rubi
4 inches on 35 baja MTZs
Stock rubi stuff(D44s, lockers, skids, etc...)
Kitchen is offline
post #7 of 24 Old 02-22-2011, 06:50 PM Thread Starter
XJforlife
Im planning on getting the exhaust replaced with a 2.5 inch this summer at a local shop with a delta 40 and high flow cat. Ive heard that replacing the mechanical fan is good to do. Any ideas?
post #8 of 24 Old 02-22-2011, 06:58 PM
Kitchen
im not sure about the fan. all ive done is, gutt my cat-converter, flowmaster 40, k&n cold air intake, e3 sparkplugs, royal purple oil, zmax engine additive, and a homebrewed hydrogen generator. ive seen a 8 mpg increase but when i get my bigger tires that will prolly go down a bit
- 99 XJ
Build thread:
- 03 TJ Rubi
Kitchen is offline
post #9 of 24 Old 02-22-2011, 07:30 PM Thread Starter
XJforlife
I think for gas mileage and cash the 2 inch may be the best option. Do i need to lower the transfer case for that and who builds the best kit? also, does anyone know a good bumper or grille guard for cheap? i wanna mount some running lights on it.
post #10 of 24 Old 02-22-2011, 07:38 PM
Kitchen
if you go with a 2 inch you shouldnt need a t case drop kit.
- 99 XJ
Build thread:
- 03 TJ Rubi
Kitchen is offline
post #11 of 24 Old 02-22-2011, 11:01 PM Thread Starter
XJforlife
What do you suggest for lights? I wanna run some on the roof. Also, what safari racks are best?
post #12 of 24 Old 02-22-2011, 11:04 PM
Green4dr
at 2'' you may have some vibes but it is dueable. i have 2'' on 31s and i get some vibes around 70ish but then they go away. my gas mileage goes from 12-18. id say 2 or 3'' lift on 31s. especially if your just gunna do some snow and mud you dont need a lot of flex. and i am gunna be doing my exhaust soon also to a 2.5 but i only imagine that my mpg will drop due to me wantin to hear it.
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #13 of 24 Old 02-23-2011, 12:15 PM
Mighty Thor
General information about lifting Jeeps. As you go up you increase the air resistance that the jeep has on the highway. As you add bigger tires and wheels you also add weight that must be turned by the engine and moved down the road. all of this will decrease your mileage.
There isn't really any effective way to add weight and wind resistance and keep the same mileage. You can reduce the mileage loss by gearing changes and tuning and other things, but gravity is a constant and weight takes power to move.
In my build thread I recorded the changes that took place on the jeep from stock to 3 inches of lift, you can use the link in my signature if you want to see how I did things and what the results were and looked like.
Is that supposed to look like that?
Mighty Thor is offline
post #14 of 24 Old 02-23-2011, 01:55 PM
mosh-n-roll
2009 JK Wrangler
If you look in the classifieds on this forum you could probably find a budget boost for cheap. Consists of coil spacers and extended shackles. Fairly easy to install, and there's a good chance you won't have any driveline vibrations, although every Jeep is different. Mine had this setup when I bought it and had no vibes. I sold my budget boost on this forum to some guy for $50 bucks including shipping...coil spacers were used, but the shackles were brand new rough country extended shackles. If you go this route its very cheap, and if you're willing to trim your fenders you could squeeze 31's under there too.
2009 jk 2 door 6 speed.
Sold - 98 4 door XJ, 4.0, AX15, 8.25 w/ Aussie, HP-D30 w/Aussie, 4" IRO lift, custom front bumper, 34x10.5 Super Swamper LTB's.
mosh-n-roll is offline
post #15 of 24 Old 02-23-2011, 02:00 PM
Hussler
1992 XJ Cherokee
If I was in your situation:
1. 3" lift
2. JK rubicon take off moabs
3. lights in grill (less wind resistance than on roof)
I wouldnt go with a crazy mud tire, i would keep it to the M+S variety, like a cooper discoverer tread
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
bumpers , drivetrain , lifts , lights , tires
Just got a sweet 1 owner 92 xj laredo 123k should I lift it if so which lift 3" SomerJeep XJ Cherokee Technical Forum 9 07-08-2010 08:08 AM
cherokee adds sega2010 XJ/MJ Cherokee Non-Technical Forum 2 02-22-2010 07:15 PM
Is my informal list of lift parts complete? (3.5-4" of lift not from a kit) GeologistFelix XJ Cherokee Technical Forum 1 12-28-2009 09:10 PM
what adds more to the roll-over factor - rear or roof mounted tire carrier BigOrangeXJ XJ Cherokee Technical Forum 15 01-25-2006 11:40 PM
OME AAL adds how much lift? JBassXJ XJ Cherokee Technical Forum 5 12-20-2005 10:35 AM
