Help! Xj knocking on startup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Help! Xj knocking on startup
ZONE 4.25" combo lift for TJ available at Rockridge4wROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete
Unread 09-15-2014, 10:07 AM   #1
Bsrock
Hello my jeep xj has recently been knocking when I start it up. It seems to quiet down after about 5 seconds. It also knocks when I put it on park in my driveway. I recently changed out the water pump, and took it to get the oil changed with high mileage oil. It has 160,000 miles on it and the oil pressure is normal. Not sure what it is? Please help.
Bsrock is offline   Reply With Quote Quick reply to this message
Unread 09-15-2014, 10:28 PM   #2
1stockjeep
1993 XJ Cherokee
Could be anything from a loose or cracked flywheel to a bad lifter, don't forget the catalytic convertor can rattle when bad as well, pin point the knock and report
1stockjeep is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 09:00 AM   #3
cavalier
Push against the distributor cap with your hand. Try wiggling it a bit- may require a bit of force. See if the knock change
cavalier is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 09:10 AM   #4
denverd1
you're in Florida, so running heavier oil may be an option
denverd1 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 08:59 PM   #5
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What brand of oil filter did you use?
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 09:27 PM   #6
AZ Jeff
2014 JK Wrangler
Knock, or a metallic rapping?
Knock generally implies a deep solid sound, and most engine issues that create that sound don't go away after a few seconds.
A metallic rap or tap sound is not uncommon on engine startup with worn hydraulic valve lifters.
Which type of sound do actually have?
AZ-Jeff
1992 XJ -- stock (RIP)
2000 XJ -- lots of basic mods. Sold to fellow forum member. I miss it.
2014 JK -- the project is just starting!
AZ Jeff is offline   Reply With Quote Quick reply to this message
