help with turn signal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > help with turn signal
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-23-2011, 08:25 AM   #1
cwilliams469
1995 XJ Cherokee
found out my right rear lights barely work
no back up, hazard or turn lights on that side but brake light is fine...
got new assembly and have same problem starting to think short or fuses
anybody got a schematic or know where the relay or fuse is
in cab the right flasher indicator flashes quickly but doesnt work outside
any ideas?
cwilliams469 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2011, 12:11 AM   #2
JWELK
What about the tail/marker light. If the brake lamp is good, the grounds should be ok. I don't have a print for your year, but I don't think there are left / right fuses for turn signals or back ups. Sounds more like broken or wet splices where the left and right sides split.
Take the assembly out, set parking brake, put the key in run, and put tranny in reverse and measure the voltage on the wires going to the back up light. Leave the lamp in place, and stick the red meter lead in the wires. I have found a sewing needle with a jumper lead works well. (it doesn't make as big a hole, cover with liquid tape when done, nail polish will work if you don't have liquid tape) Hopefully you will find approx 12 volts on one wire and 4 on the other. That indicates you have a poor ground. More than likely you will have 9 and 0.
Happy Thanksgiving,
Jim W
JWELK is offline   Reply With Quote Quick reply to this message
