-   -   Help! Stumbling, hesitating and stalling. (http://www.jeepforum.com/forum/f11/help-stumbling-hesitating-stalling-1496964/)
aldersonfilm 03-21-2013 03:14 PM
So the jeep has always had a slightly rough idle and tracking down the source of it has been a nightmare, so I gave up awhile ago. Today however, I went to back out of the driveway and when I turned the wheel, it stalled out. I started it back up and started driving, though it stumbled on every acceleration and bump in the road. The idle isn't low or high, just a little rough like it's always been. There's quite a lot of valve chatter, though I know the 4.0s are not exactly quite engines and it's always been a bit chattery.
THINGS ITS NOT: I've replaced plugs, wires, cap and rotor, air filter, fuel filter, throttle position sensor (and adjusted it using the transmission connector because I had a shift issue,) battery, and I've cleaned up the ground at the base of the dipstick a bit.
CJ7-Tim 03-21-2013 06:05 PM
Test the O2 sensors. Stumbling, hesitating, and stalling are most often caused by O2 sensor issues.
A leaky exhaust system or leaky fuel injector(s), or bad compression or leaky valves, bad plugs, wires, cap, rotor, HV coil, and so on, or combination of these, can also cause a lean or rich condition that gives you high or low O2 sensor readings that are not the O2 sensors fault, so try and verify those other items also before buying parts like an O2 sensor to fix your problem.
www.picoauto.com/applications/lambda-sensor.html
O2 sensor testing
1987-1990 Renix
For the Renix years, 87-90, the O2 sensor has 3 wires, 2 black and 1 orange. The orange wire (largest gauge of the 3) is the 12-14 volt power that comes from the O2 sensor heater relay on the passenger side firewall, and that powers the internal heater in the sensor so that the sensor can work at idle, and almost immedietly after start up. Loss of that power will hurt gas mileage even with a good O2 sensor.
One of the black wires is a common ground for the heater power and O2 signal to the ECU, so a poor ground will give a voltage feedback from the heater power input, to the ECU causing poor mileage even with a good O2 sensor.
The third wire, also black is a voltage feed wire, 5 volts, from the ECU to the O2 sensor. The O2 sensor is an O2 concentration sensitive variable resistor. At optimal O2 concentration the 5 volt input feed to the O2 sensor drops to 2.45 volts due to losses across the O2 sensor to ground. That same wire if disconnected from the O2 sensor will read 5 volts constant to ground.
At idle that voltage should read 1-4 volts oscillating quickly back and forth roughly once every second. At 2000 rpm it should run between 2 and 3 volts max, and is optimally running between 2.3 and 2.6 volts at 2000 rpm (in park). A digital meter can NOT be used for reading the O2 sensor voltage, but it can be used to test the ground and the 12-14 volts to the heater and the 5 volt feed from the ECU with power on and engine off. You must use an old style analog meter with the needle gauge on the display to see the voltage swing back and forth with the engine runing.
If the O2 sensor readings are not right, say they read 4 volts or 1 volt steady, you have a problem. BUT before you blame the O2 sensor make sure it has good wiring, and make sure the proper voltage is feeding it, by turning power on, engine off to read the engine off voltage feeds (12-14 volts on the orange wire, and 5 volts on one of the two black wires), and ensure the ground wire (power off) reads less than 1 ohm to the battery negative post.
A leaky exhaust system or leaky fuel injector(s), or bad compression, bad rings or leaky valves, bad plugs, wires, cap, rotor, HV coil, and so on, or combination of these, can also cause a lean or rich condition that gives you high or low O2 sensor readings that are not the O2 sensors fault, so try and verify those other items also before buying parts like an O2 sensor to fix your problem.
1991-2001 HO
For the HO years, 91-02, the O2 sensor has 4 wires. One wire is the 12-14 volt power that comes from the O2 sensor heater relay on the passenger side firewall (unless they moved them in later years to the relay & fuse boxes?), and that powers the internal heater in the sensor so that the sensor can work at idle, and almost immedietly after start up. Loss of that power will hurt gas mileage even with a good O2 sensor.
Two black wires are grounds for the heater power and O2 signal to the ECU. A poor ground will limit current to the O2 sensors heater or cause an error in the O2 sensor output voltage read by the PCM (ECU) causing poor mileage even with a good O2 sensor. Test the 2 ground wires with power off. Test between the wire end at the sensor and the battery negative ground post. It should read less than 1 ohm.
The last wire, #4, is a signal feed wire, 0-1 volts, from the O2 sensor to the PCM (ECU) sensor. The O2 sensor is an O2 concentration sensitive variable voltage generator. At optimal O2 concentration the O2 sensor puts out 0.45 volts.
At idle that voltage should read 0.1-0.9 volts oscillating quickly back and forth roughly once every second. At 2000 rpm it should run between 0.4 and 0.5 volts max (in park). A digital meter can NOT be used for reading the O2 sensor voltage, but it can be used to test the grounds and the 12-14 volts to the heater. You must use an old style analog meter with the needle gauge on the display to see the voltage swing back and forth.
If the O2 sensor readings are not right, say they read .1 volts or .8 volts steady, you have a problem. BUT before you blame the O2 sensor make sure it has good wiring, and make sure the proper voltage is feeding it, by turning power on, engine off to read the engine off voltage feeds (12-14 on one, and ensure the ground wires (power off) reads less than 1 ohm to the battery negative post.
If any one of the grounds or the O2 sensor to ECU/PCM wires reads a high voltage chances are the wiring harness is damaged and the 12-14 volts for the O2 sensor heater is getting through a bad spot in the wires insulation and contacting a ground wire or the O2 sensor wire feed to the ECU/PCM. This is not the O2 sensors fault, but a wiring problem.
The time now is 04:27 PM.
