Help Question! - JeepForum.com
post #1 of 7 Old 12-07-2012, 10:54 AM Thread Starter
Loveland-WJ
Help Question!
Hey guys, I have a 96 XJ 4.0 4x4 auto.
Last night on my way home theSerpentine Belt (less then 6 months old) fell off. When I got home I had rad fluid spewing out and the reservoir tank was full. Some time later, I put the belt back on and went to start it and the belt fell off, right away, secs. Tried it again and the same thing happen... It happens so fast I can not see what pulley it causing it.
After doing some research ....I see issues with the Harmonic Balancer can cause this, but I do not think that this is my case. It's not moved forward or back. Belt is in-line.
My question is: Can the Water Pump goes out and cause this? My pulley for the Water Pump is hard to turn and feels grinding.
Let me know what you think...
Thanks Guys.
2001 WJ Black Limited 4.7 - 3"(2BB"+1"UC) lift, IRO track bar, DT shocks, 245x75x17MTs (31.7")
Loveland-WJ is offline
post #2 of 7 Old 12-07-2012, 11:01 AM
BlueBadger
Yes that is the problem. Time for a new water pump. Same thing happened to me in '07
BlueBadger is offline
post #3 of 7 Old 12-07-2012, 11:11 AM Thread Starter
Loveland-WJ
Great, Is this easy to replace...Looking it up now.
post #4 of 7 Old 12-07-2012, 05:27 PM Thread Starter
Loveland-WJ
Thanks Blue....Yep my Water Pump was seized. It was not that hard to replace pretty easy fix. My jeep is back on the road.
post #5 of 7 Old 12-08-2012, 07:38 PM
BlueBadger
Good deal man. Sorry I didn't get back to you sooner. If you didn't then it would probably be a good time to throw in a thermostat and flush the cooling system as well.
post #6 of 7 Old 12-09-2012, 08:34 PM
tsc
another fun one like this is a siezed alternator..... had the bearing fall out, shaft siezed, belt squealed
tsc is offline
post #7 of 7 Old 12-10-2012, 07:59 AM
BlueBadger
Agreed. And why in the world would they stick the main electrical item on an OFFROAD vehicle so low to the ground/water and have it to be that tight and a PITA to change?
harmonic balancer , serpentine belt , water pump
