help properly removing serpentine belt 1988 - JeepForum.com
post #1 of 2 Old 04-04-2011, 03:07 PM Thread Starter
nameless
1988 MJ Comanche
i've read a few different things and know how to do it on the newer style
any pics or write-ups on exactly what to loosen
ultimately i'm trying to replace the alternator, thanks
88 MJ 4.0L, AX-15 swap, 6.5" LA, SOA, 30/44, geared, detroit in the back, 37's, blah blah blah
reno4x4.com
nameless is offline
post #2 of 2 Old 04-04-2011, 06:06 PM
keepishop
1989 XJ Cherokee
The adjuster is the power steering pump. There are a few bolts front and back of it to loosen so it can pivot, and then the tension adjuster is at the bottom of it. If you remove the airbox (two bolts) and efan (also two bolts), it's much easier to work with.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
Serpentine BElt armystrong2121 XJ Cherokee Technical Forum 5 04-06-2010 10:01 PM
need help removing serpentine belt on a 88 4.0 robdoggydog1 XJ Cherokee Technical Forum 9 12-24-2009 08:18 AM
Serpentine Belt Help XJChris98 XJ Cherokee Technical Forum 6 10-01-2006 11:05 AM
Serpentine belt? 89Cherokee4x4 XJ Cherokee Technical Forum 9 09-14-2006 11:45 PM
Serpentine Belt ??? Osteonis XJ Cherokee Technical Forum 7 03-10-2005 02:19 PM
