help please - JeepForum.com
post #1 of 11 Old 07-19-2017, 04:33 PM Thread Starter
antman420XJ
1990 XJ Cherokee
help please
I have a 1990 Cherokee Laredo 4.0l and trying to figure out a problem.. My biggest problem is I'm no mechanic and not loaded with money lol.. My jeep all of a sudden died on me while driving. I was able to put in neutral and starts right back up only to have it die on me 20yards later.. Did a little research and I replaced my CPS sensor cause that seem to match my problem. It ran ok for about an half hour and right back to the same thing.. I have also replaced my o2 and knock sensor any other suggestions with out having a repair shop charge my an arm and a leg to diagnose the problem.. Thanks in advance
antman420XJ is offline
post #2 of 11 Old 07-19-2017, 05:16 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You are wasting money on parts which have no effect on it dying. Namely the O2 sensor and knock sensor.
TEST your new CPS.
Directions here:
http://cruiser54.com/?p=50
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 11 Old 07-20-2017, 09:00 AM Thread Starter
antman420XJ
1990 XJ Cherokee
The knock sensor and o2 sensor were replace when i replace my cracked exhaust manifold simply cause the heat from the busted exhaust manifold melted the wiring.. Thanks for the link and could it possible be fuel pump related?
post #4 of 11 Old 07-20-2017, 09:02 AM Thread Starter
antman420XJ
1990 XJ Cherokee
TY again for link.. tested the new CPS and only got .2 reading so hopefully the next one will do the trick.. Is there any part site you would recommend?
post #5 of 11 Old 07-20-2017, 01:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Be sure to modify it per the link.
post #6 of 11 Old 07-23-2017, 12:18 AM
KF4SQB
1994 XJ Cherokee
Anywhere you can get an OEM Mopar sensor. Aftermarket versions are known to fail, if they ever work properly.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #7 of 11 Old 07-24-2017, 08:24 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I don't know anymore. I part out Jeeps so I have a constant supply.
Try doing the drill trick on the one you have.
post #8 of 11 Old 07-26-2017, 03:44 PM Thread Starter
antman420XJ
1990 XJ Cherokee
I did the drill and went to a 3/8 hole and still no good.. Went ahead and changed out the map cause already knew that was not working properly.. Running real rich and very poor gas milage.. After the MAP ran with idle real low but did responded well for about 30min and right back to where I started.. Cranks up but won't stay running.. Going to try to find a mopar CPS but not having any luck
post #9 of 11 Old 07-26-2017, 03:45 PM Thread Starter
antman420XJ
1990 XJ Cherokee
Cruier54 Do you have a used CPS up for sale?
post #10 of 11 Old 07-26-2017, 05:33 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I don't think it's the cPS. Wouldn't run at all. Super rich is MAP circuit and vacuum generally.
post #11 of 11 Old 07-26-2017, 07:17 PM
Nick05
1994 XJ Cherokee
Will it stay running if you give it a little skinny pedal? If so, try cleaning the iac(it's real easy) and throttle body. Might also check fuel pressure/replace filter.
Nick05 is online now
