help please - JeepForum.com
post #1 of 13 Old 06-21-2013, 05:56 PM Thread Starter
ae1440
Help me out please
i have a 98 cherokee limited 4.o 230k miles
its been giving me trouble ideling after warm and terrible mpg and a real bad sputtering on the highway!
Just did a full tune up plugs wires oil change. still nothen.
took and cleaned the idle control valve and that helped in town but not mpg or sputtering...
replaced a broke O2 sensor fuse then cleaned the O2 sensor in town it seemed much better but then got on the highway and its sputtering as if its gasping for air and mpg is 10-12 used to be a low of 18- and high of 22
also replaced the oil pressure switch since that gauge was dancing and that helped that issue
for the life of me i cant find or figure out why the highway is so terrible on mpg and car doesn't excel or hold gas without sputtering terribly
ae1440 is offline
post #2 of 13 Old 06-21-2013, 06:33 PM
sAe23
1995 XJ Cherokee
Maybe your CAT is clogged?
Do a highway run to get it up to running temp then check to see if the CAT is glowing.
Or take it to a good smog tech and they can test it...
sAe23 is offline
post #3 of 13 Old 06-21-2013, 06:35 PM Thread Starter
ae1440
i forgot to add my cat was replaced brand new about 3 months ago
and tomorrow i have parts arriving for fan clutch and new water pump
ae1440 is offline
post #4 of 13 Old 06-22-2013, 01:22 PM
sAe23
1995 XJ Cherokee
What plugs did you use?
sAe23 is offline
post #5 of 13 Old 06-22-2013, 08:22 PM Thread Starter
ae1440
i cant remember what plugs whatever orieley carries... i just found out it had a p0171 error says its running lean.. getting a new upstream o2 sensor tomorrow hoping that helps
ae1440 is offline
post #6 of 13 Old 06-23-2013, 05:04 AM
JMH21814
1997 XJ Cherokee
This may be a silly question, but is your exhaust manifold cracked? Mine was and my mpgs dropped in half. Also, added air (oxygen) entering before the upstream O2S will trick the sensor into thinking your running lean, therefore, CPU will dump more gas into cylinders possibly causing slight wet fouling (slight skip) and P0171 (lean bank 1). Very interested in what you find, please keep us informed. Good luck!
JMH21814 is offline
post #7 of 13 Old 06-23-2013, 08:07 AM
AmbuGrl
AmbuGrl's Avatar
Trace all of the wires on your upstream sensor. Ours has similar issues and we had a broken wire. (same code too) We fixed it and replaced the sensor, no more issues.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #8 of 13 Old 06-25-2013, 07:13 AM Thread Starter
ae1440
The wires are all attached, also i did have to splice a year ago because of that reason!... will check manifold but unsure what exactly to do other than look at it i guess? Theres so much grease buildup so ill have to clean it first but i will update soon!
ae1440 is offline
post #9 of 13 Old 06-28-2013, 07:55 AM Thread Starter
ae1440
update
i didnt see any crack in the exhaust manifold, next i looked at fuel injectors... manually unplugged one at a time! One in particular after being unplugged didn't seem to foul the engine any more than when it was plugged in... so i ordered a set of bosh fuel injectors to arrive early next week and i'll update then!
Any suggestions or tips for changing out fuel injectors?!?!
ae1440 is offline
post #10 of 13 Old 06-28-2013, 02:00 PM
sAe23
1995 XJ Cherokee
Maybe you should test the circuit first??
sAe23 is offline
post #11 of 13 Old 07-08-2013, 08:16 AM Thread Starter
ae1440
New injectors help with MPG but doesnt cure my problem, reset CEL going to see if it poulls the same code later today
ae1440 is offline
post #12 of 13 Old 07-12-2013, 01:57 PM Thread Starter
ae1440
gas mileage dropped suddenly to well below 12 oh highways when i was getting 18-20, idles still feel like engine will die and it has almost no acceleration unless its to the floor and even that my check engine light blinks when i do accelerate
ae1440 is offline
post #13 of 13 Old 07-12-2013, 02:19 PM Thread Starter
ae1440
replacing throttle position sensor next, some threads having the same symptoms say this fixed them
ae1440 is offline
