HELP! options to replace a radiator - JeepForum.com
post #1 of 10 Old 04-19-2003, 12:46 PM Thread Starter
89Cherokee
Well my girlfriends 89 Cherokee started leaking a few days ago. We've had some cooling problems, but were doing good for the past month or so. But now the radiator is leaking. Its very slow, but enought that I want to replace it before she gets stuck somewhere.
What options do we have for a new one? I've heard alot about upgrading to the newer systems. What all is required for the conversion, and how much $$? Are there any good aftermarket replacements for the existing system, or would it be a waste to upgrade the closed system? Any good places to look for a replacement?
Thanks for the help
White 2-door 89 Jeep Cherokee
4x4 auto 4.0L FOR SALE
89Cherokee is offline
post #2 of 10 Old 04-19-2003, 01:29 PM
Dacaur
Dacaur's Avatar
2008 MK Patriot
here are two write ups on upgrading to the newer system...
http://www.off-road.com/jeep/cheroke.../radiator.html
http://www.dirtdevils.org/briantechtippage4.htm
or just replacing the current one http://www.ilovejeeps.com/tech/article.cfm?ID=24
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline
post #3 of 10 Old 04-19-2003, 03:24 PM
EricsXJ
The Post man
EricsXJ's Avatar
Along with converting to an open style cooling system as those articles show, putting in a GDI 3-row radiator would be the best and sometimes its even cheaper than the stock 2-row replacements. There should be a tech article for the GDI 3-row installation on www.jeepin.com
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 10 Old 04-19-2003, 05:48 PM
RockinXJ
RockinXJ's Avatar
While you've got the radiator out, you might as well replace the water pump. It doesn't make the job too much longer, and it will only cost you about $25 from AutoZone. Be sure to have some RTV silicone sealant on hand too.
If you light a fire for a man you'll keep him warm for a day, but if you light a man on fire, you'll keep him warm for the rest of his life!
I ♥ Transitive Pictograph Verbalizations
RockinXJ is offline
post #5 of 10 Old 04-19-2003, 10:25 PM
STAN 92XJ
STAN 92XJ's Avatar
http://www.jeepradiator.com/radiator...model=cherokee
$135 for a 3 row. Mine works great!!!
Good luck!
1998 ZJ, 4.0l, 1.5" BB, 16" Moabs
87 Ranger-SC, 5" Custom, 33" GY
97 ZJ-Sold
92 & 00 XJ-Sold
STAN 92XJ is offline
post #6 of 10 Old 04-19-2003, 10:57 PM
Dazz
I soon will be replacing the stock radiator for the GDI 3 row soon.
This past weekend, I flush the entire coolant system, purchase new thermostat, added Redline Water Wetter, and check the Fan Clutch (still had resistant.) The driving temps still pegs out at 235 degrees F.~
Autozone has the GDI for $129.00 and in stock!
91' Black XJ
6" RE Lift, 34" LTB on 15x8 Unique 42
Dazz is offline
post #7 of 10 Old 04-20-2003, 10:22 AM
ronsurf69
Lightbulb overheating
Could be air in the return lines preventing colant flow. I had the same problem several times. You can either park it on a steep incline, nose down and fill it. Or pull the return hose at the radiator and fill the radiatior and the block. It worked for me.
What idiot designed a radiator without a fill cap?
Ron
89 square tail
ronsurf69 is offline
post #8 of 10 Old 04-20-2003, 06:23 PM Thread Starter
89Cherokee
Thanks for all the replies!
It actually hasn't overhearted for a while, its just a leaky radiator. We're thinking of just swapping it for the GDI 3-core unit and keeping the closed system, primarily due to budget constraints. Would we be making a mistake by not switching now?
Its been in the 90's a few times these past few weeks, and with the a/c on sitting in traffic the idiot light never came on. Hopefully the upgraded radiator will keep things cool on the 100+ days here in TX.
The best I've found for the GDI is $109 + $9 shipping, but I haven't checked with autozone yet. If they have it for $129 in stock we'll probably just get that and save the shipping hassle.
post #9 of 10 Old 04-21-2003, 01:29 PM
8inchXJ
1990 XJ Cherokee
I went to www.radiators.com and purchased a GDI 3 core for $120 shipped. Just make sure you know if you have an open or closed system. Works great, gotta drive it hard to get it above 210 degreses
1990 XJ, '01 4.0, ARB,
8 Inch RR, Swampers, etc
8inchXJ is offline
post #10 of 10 Old 04-21-2003, 02:18 PM
RockinXJ
RockinXJ's Avatar
89CHEROKEE, what part of Texas do you live in? If you need the help, I might be able to drop by. LMK
RockinXJ is offline
Radiator leak. Should I replace? leland_7 XJ Cherokee Technical Forum 11 12-01-2009 09:22 AM
Need to replace radiator; what should I go with? ghengis86 XJ Cherokee Technical Forum 7 02-12-2009 04:22 PM
Replace 1996 Radiator? cid98 XJ Cherokee Technical Forum 7 07-15-2008 09:01 PM
Replace 1996 XJ Radiator? cid98 XJ/MJ Cherokee Non-Technical Forum 0 07-14-2008 03:03 PM
how to replace radiator on a 98? Habibi XJ Cherokee Technical Forum 3 10-11-2006 11:16 AM
