help: old injector plastic clip in manifold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > help: old injector plastic clip in manifold
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-19-2015, 08:12 PM   #1
D2theP
1988 XJ Cherokee
i'm replacing my fuel injectors. the clip that held the old fuel injector to the fuel bar fell into the frickin intake manifold. am i gonna have to pull the manifold to get to it and remove it? what happens if i leave the old clip in there? frickin, frick, frick frick!!!!!
please advise..... thanks
D2theP is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 04:30 AM   #2
Ferryman
All I can think of is remove the valve body from the inletmanifold and try to find the clip with a magnet on a (flexible) stick.
Good luck...
Edit: assuming you are talking about the steel clip that holds the injector to the fuelrail?
Ferryman is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 07:52 AM   #3
D2theP
1988 XJ Cherokee
it's effing plastic. but, it's gotta come outta there, huh?
Unread 07-20-2015, 08:28 AM   #4
Paradise XJ
1988 MJ Comanche
It's definitely gotta come out. I'd take off the throttle body and try to find it visually. Then see if you can get one of those grabbers in there and snag it (I'm talking about the small part retriever, not your gramma's grabber). If it (can) drop into a cylinder you'll have even a harder time getting it out of there.
The other option is to remove the manifold(s). In the future, when you open holes in your engine, have some tape or gauze type pads to stuff in there to keep dirt and foreign objects out. Good luck.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 08:40 AM   #5
2000_XJ_MI
Get a section of clear hose from your home improvement store that's big enough to feed into either the injector hole or spark plug hole...whichever is bigger. Slip 2" into the hose of your vacuum/shop vac and then tape the hell out of it to seal it off. Insert your clear hose and turn on the vacuum to try to suck out the clip. You could also try to blow compressed air into the injector hole w/ the spark plug out and maybe you'll get lucky and have the clip shoot out.
2000_XJ_MI is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 09:31 AM   #6
D2theP
1988 XJ Cherokee
we decided to try the vacuum approach... wish me luck...
Unread 07-20-2015, 11:39 AM   #7
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Vacuum or blow it out. It won't get into a cylinder if you don't start the engine, and even then, it's just plastic, it will be vaporized in the cylinder should it ever get that far.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 06:55 PM   #8
D2theP
1988 XJ Cherokee
got it out and injectors installed. thanks y'all.
