Help OD not working!! Stuck on 3rd Maybe?? - JeepForum.com
post #1 of 1 Old 03-04-2012, 03:04 PM Thread Starter
95_Jeep_40L
Hey guys I'm new to this forum I have a 95 Jeep Cherokee Sport 4.0L Inline6 4x4 Automatic Transmission so I got it from my boss for a few days worth of work online problem is when I put it on Drive it takes off very slowly (while gasing it) until you hit right about 25-35 mph then its fine but if I have to slow down then the same thing happens. I can drive it from the 1st-2nd gear (low) and it takes of just fine then to 3rd then to Drive, There is a small decrease in rpms when I change from 3rd to D when going above 35-40 mph so I'm not quite sure if OD is stuck on 3rd or maybe the gear is longer.
My boss said he did a tune up 3 months ago because he was planning to sell it but he also did a tranny fluid change and filter also and since then its started doing what I explained above. Before that it drove fine, Im not sure what could be the problem shift solenoids?? output or input speed sensor?? The tranny Computer??
Any input will be helpful thanks for looking!
Thank you for your time!!
95_Jeep_40L is offline
cherokee , gear , od , transmission
'96 XJ - Dash Lights Not Working (Wiper Fluid Light Stuck on) JeepYJ44 XJ Cherokee Technical Forum 2 08-04-2011 03:33 PM
Worst Stuck Picture Thread Or Just Stuck Bigbadwolf54 XJ Cherokee Technical Forum 19 08-13-2010 06:04 AM
Wow what a night; A STUCK: Quad, Friends moms WJ, A stuck bulldozer, Wrecker, Dodge. Element96x XJ/MJ Cherokee Non-Technical Forum 35 12-12-2009 04:54 AM
Piz help!!! np 231 stuck in neutral trany also stuck (ax-15) help!!!!! GB2DOORXJ XJ Cherokee Technical Forum 0 02-06-2009 10:07 PM
First time out... Got stuck. 4x4 not working? xjguy XJ Cherokee Technical Forum 9 08-08-2005 01:08 AM
