Help Need 89XJ Starting to Run Like #/!% - JeepForum.com
post #1 of 8 Old 07-21-2005, 08:38 PM Thread Starter
AngryDog
Question Help Need 89XJ Starting to Run Like #/!%
OK here is what I got. I bought a 89XJ 4.0I last fall went through the whole thing mecanically, plugs, rotor, wires, cap, cold air intake, IAC cleaned, CPS, MAP sensor, all new vac hoses, fuel pump and filter, battery and cables, cleaned the carb and a lot of other stuff. It has run like a top until about two weeks ago. It started to run almost like it was skipping but I don't think so. I was only doing it when I was going uphill until yesterday. Today I take it into town and it ran pretty good. Then this after noon I was helping out a bud and it was like -=-=-=-=. Chugging almost to the point of stalling. WHen I got it moving some and increased the gas quiet a bit it seemed to smooth out some. But I still could feel it chugging a bit. Parked in the drive until tommrow. Any ideas my fellow XJers? Ialmost seemed today to be not getting fuel, but when I increased the throttle it smooths out quiet a bit. Then back to chugging at low speeds. Give me some ideas where to start looking.
In His Service...
God says, “Choose for yourselves today whom you will serve”
As for me and my house, we choose the Lord. Joshua 24:15
AngryDog is offline
post #2 of 8 Old 07-21-2005, 09:43 PM
ChaoticBastard
Clogged Cat Converter?
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #3 of 8 Old 07-21-2005, 10:06 PM Thread Starter
AngryDog
Help
Thanks but I forgot to mention I also changed the exhaust from the manifold all the way back, including the cat and O2 sensor. Anymore info?
In His Service...
AngryDog is offline
post #4 of 8 Old 07-21-2005, 10:20 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
When my coil started going out, it would bog a little at lower rpms. The it eventually would die if the RPMs went lower than 1100.
I would say get a fuel pressure gauge and make sure that the pressure isn't dropping at the surge. If it isn't that, I'd say look into the idea of a bad ign module to the coil or a bad coil itself.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 8 Old 07-22-2005, 12:29 AM
Kuasimodem
Kuasimodem's Avatar
Check all of your vacuum lines for cracks, especially around the ends. Heat from the engine components can cause them to harden and crack at those locations.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #6 of 8 Old 07-22-2005, 09:33 AM
dka1ser
My S-10 had odd symptoms when the coil was going out as well, runs good intermittently etc.. Does it backfire any, under heavy load?
Ign. module and coil are easy to test, Autozone even will best the module and coil for you I believe. A fuel press gauge isn't too expensive either. I
  • 4x4, 4.0l, auto trans, 8.25" rear
  • brush guard, LT235/75R15 BFG's
  • class III hitch for pulling my Chris Craft
  • soon to come, Rusty's 3" lift with full leafs
Other toys:
dka1ser is offline
post #7 of 8 Old 07-22-2005, 10:23 AM
Txaircraftmech
Arrow
I have to agree with those guys, yes I believe its the distributor that might be cracked. We always check that on Aircraft engines because we cannot have that flying. Where would you pull over in the sky so it has to be in a working top before it leaves the ground.
Txaircraftmech is offline
post #8 of 8 Old 07-22-2005, 01:06 PM Thread Starter
AngryDog
Thanks for the Help
Thanks for all the help and ideas. After a scary trip into town for a doctors appoinment, dam thing started up again, chugging, backfire, and stalling. So much so the muffler overheated and caught the rug liner on fire. Then I went to NAPA and got new plugs, wires, cap and rotor also seafoamed her. Swapped them out all to no avail. Went back and done somemore research and found a couple of posts on it could be the ballast resistor. Jumped the thing and viola, it run like a top again. Took it to town and got a new one. Back in bussiness.
Question:
Just what does that thing do? I new it didn't start wothout it but I did not know it could make a viechle run like that.
In His Service...
AngryDog is offline
Will a 96 Comanchee Hood fit my 89XJ? CharlieMopps XJ Cherokee Technical Forum 6 12-04-2009 11:13 AM
89xj build with ?s, tips, and ideas.... dead2rollin XJ Cherokee Technical Forum 36 11-14-2009 10:30 PM
I want to go doorless on my 89XJ gasmandave XJ Cherokee Technical Forum 3 09-12-2008 02:05 PM
Pray for my '89xj nhpso224 XJ Cherokee Technical Forum 3 01-27-2006 10:06 AM
89XJ Unibody queston BadXJ XJ Cherokee Technical Forum 1 09-26-2002 10:22 AM
