Quantcast HELP my XJ is afraid of the water!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > HELP my XJ is afraid of the water!!
Old 06-14-2008, 06:40 PM   #1
powelljwp
1994 XJ Cherokee
So I took my new to me 94 xj 4.0L out to go wheeling today for the first time. I just bought the jeep Wednesday and put in the sunpro triple gauges water temp replaced front OEM water temp sensor/ oil pressure T off of original sensor/ voltmeter (not hooked up yet) the gauges work great. So the first time I drive in the rain with big 1’ deep puddle on the street bout ¼ mile before the trail it starts to sputter. 500 feet into the trail(dirt road) it dies won’t restart. What would cause this? I know what fixed it time or taking out the spark plugs. But after I fixed it I proceeded on the trail and it happened again. There was Still water on the trail. After I fix it again I decided to go home and stopped on a dry trail on the way home no prob wheeled alone for about 20min no prob
any help would be great
powelljwp is offline   Reply With Quote
Old 06-14-2008, 07:03 PM   #2
the_weirdo
Did you go thru the water puddle? How fast? If you are tearing thru water you probably got some water on the electronics.
the_weirdo is offline   Reply With Quote
Old 06-14-2008, 11:41 PM   #3
89warwagon
1989 XJ Cherokee
pop off the distributor cap and have a looksee.....you might have gotten water in there.
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline   Reply With Quote
Old 06-15-2008, 05:16 PM   #4
powelljwp
1994 XJ Cherokee
i was tearing throught the water what electronics would i have got wet? i know it was not a wet distributer b/c i replaced the cap and rotor and it was bone dry.
Old 06-15-2008, 05:52 PM   #5
1986cherokee
1986 XJ Cherokee
I did the same with my 2.8 and got a tiny little bit of water in the carb not enough to do much damage but it sputtered and stalled. i let it dry for a while it started right up, and im getting a new engine anyways. be carful with that though. if you were tearing through a 1' puddle u might have gotten water in the engine bay, i never drive fast through water now. even the really shallow stuff.
1986cherokee is offline   Reply With Quote
Old 06-15-2008, 05:57 PM   #6
myriad360
The XJ wiki here is pretty good.
http://www.jeepforum.com/wiki/index.php/XJ_Cherokee
Check out the Renix troubleshooting at the bottom (that applies to you, correct?). This article, page 3, is especially helpful:
http://**********.free.fr/OWN/trouble%20shooting.pdf
Please let us know if you find a solution, this is a common problem that most people don't come back and report a solution on.
Great XJ Troubleshooting/mod sites list: http://myriad360.x10hosting.com/blog/?cat=9
2001 Jeep Cherokee 4.0 L Limited, White. Bought in Grangeville, ID 06/11/08. Stock everything.
1998 Jeep Wrangle 4.0 L, Green. Bought in Nampa, ID 02/21/09
1988 Jeep Cherokee 4.0 L, White. Bought in Vancouver, WA in 2003. 1st Jeep, White. Bought with 3" lift, added Pacesetter header and 40 series Flowmaster
myriad360 is offline   Reply With Quote
Old 06-15-2008, 07:27 PM   #7
powelljwp
1994 XJ Cherokee
well i found a solution don't go throught water!!
Old 06-15-2008, 09:37 PM   #8
myriad360
Guess so. No one seems to know exactly why...
Old 06-15-2008, 09:59 PM   #9
srmitchell
I'd just take it easy next time.
I never fly though deep puddles, in case I need to back up, for fear of depth.
I have an xj and it is blue
srmitchell is offline   Reply With Quote
Old 06-15-2008, 10:10 PM   #10
mountainpoo
1994 XJ Cherokee
when you say " i fixed it and the proceeded," what did you fix?
1994 xj
RE 3.5 superflex/RE adjustable track bar
DT3000 shocks
cragar soft 8's 4" BS
31x10.5 R15 cooper discoverer stt's
homemade snorkel
mountainpoo is offline   Reply With Quote
Old 06-16-2008, 12:50 AM   #11
1986cherokee
1986 XJ Cherokee
???no u can go through water just take it easy and dont make a big splash unless u have water protection, snorkel, ect. but in deep water dont go to slow or u can flood the engine bay, and get water in your axels..no bueno.
Old 06-16-2008, 06:31 AM   #12
powelljwp
1994 XJ Cherokee
i took out then reinstalled the spark plugs that is all then it started up no prob it took about an hour fo us to decide to do that but i would not start after one hour of sitting but then i tookout the plugs and reinstalled them and it stated
Old 06-16-2008, 07:36 AM   #13
xlr84fun
I know when i had my wrangler, i had a cone filter on it, and while at silver lake went through a puddle a little to fast and it got water on the filter. It didn't like that too much, started to sputter while i was still in the water. put it in 4low got out of the water and it died right away. took the plugs out, no water, reinstalled tried to start, nothing. took the filter off, started right up. while it was running tried to put the filter back on, sputtered like mad, then died. ended up waiting around for an hour to let the filter dry in the sun...
xlr84fun is offline   Reply With Quote
Old 06-16-2008, 08:03 AM   #14
powelljwp
1994 XJ Cherokee
we took off the hose that connects to the TB so it was just an open TB and it still would not start. the filter and box were bone dry anyway
Old 06-16-2008, 04:36 PM   #15
mountainpoo
1994 XJ Cherokee
your battery might not be able to hold a charge it could also be a tps or another sensor problem
1994 xj
DT3000 shocks
homemade snorkel
Glock Forum
