Help!!! Is My motor blown?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Help!!! Is My motor blown??
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 07-10-2014, 11:50 AM   #1
94HOCHEROKEE
1994 XJ Cherokee
I just got finished changing the valve cover gasket and now my exhaust is blueish with a heavy smell of fuel. Its Just like my Lawn mower. I dont have a cat as i'm in the process of replacing it.
Could lack of cat cause this? Or is there something I can check on the fuel rail??
94 2Dr. Cherokee Sport, 3" RC 1" Spacer, Procomp 2.5" Full packs with RC 2" Adj. Shackles, Afe Dry Flow Stage 2, 31x10.5 Gen. Grabber At2's on 15x7 Soft 8's, 2 10" Sony Xplodes, RC Rock Rails, B&M Tranny Cooler, 2 Hella 500's
94HOCHEROKEE is offline   Reply With Quote Quick reply to this message
Unread 07-10-2014, 02:10 PM   #2
93gc40
Yes lass of cat could cause this. Blue pipes signify LEAN condition. Lack of cat going to make O2 sensor think you are rich and will cause the ECU to lean the fuel mix.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline   Reply With Quote Quick reply to this message
Unread 07-10-2014, 03:03 PM   #3
94HOCHEROKEE
1994 XJ Cherokee
can I reset the ecu to fix this?
Unread 07-10-2014, 03:13 PM   #4
Timo_90xj
Timo_90xj's Avatar
What?
The O2- sensor behind the cat (if vehicle is equipped with it) is only for analyzing if the cat does it's job, and to illuminate the CEL if cat is malfunctioning. Rear O2- sensor does NOT affect air/ fuel mixture in any way.
The forward O2- sensor doesn't know if there is a cat converter installed or not. Even with no cat the forward O2- sensor will give correct readings to PCM for as long as the sensor itself is in good condition, there are no engine issues going on, or there is no exhaust leak before the O2- sensor.
To the OP:
Blue smoke means you're burning oil. Black smoke and smell of gasoline indicates you're running rich. Verify if you actually are burning oil or not. If not, your engine is ok. If you're burning oil, it can be because of multiple reasons. Since you've had the valve cover off, are you sure the crankcase ventilation system is hooked up properly and functioning as should?
Running rich can also be caused because of many things, but the lack of cat will not cause it. It is something else. You may have knocked loose a sensor connector or have forgot to plug in something you unplugged during your valve cover gasket change.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 07-10-2014, 03:43 PM   #5
94HOCHEROKEE
1994 XJ Cherokee
^^^ thank you. I reset the Ecu with no luck.
I am going to have to go through a engine schamatic to make sure everything is hooked up.... thanks again
Unread 07-11-2014, 07:47 AM   #6
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Be sure the integrity of the hose/tube from the throttle body/manifold to the MAP is perfect.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2014, 10:52 AM   #7
SSellers
Eh, sounds like you just pulled one of my moves and left something unhooked. Besides, if anyone could blow up a motor just by changing a valve cover gasket I'd like to claim ownership of that title. I've gotten into the habit of taking a notepad out with me and as I remove any bolt/connector/hose/etc I write it down, then mark it off when it's put back. Started doing this after doing some axle bearings in a car, sealing everything up, picking up a paper towel to wipe my hands, and having the axle c-clips tinkle out of the paper towel onto the floor.
SSellers is offline   Reply With Quote Quick reply to this message
Unread 07-11-2014, 01:48 PM   #8
94HOCHEROKEE
1994 XJ Cherokee
I was out there inspecting around the valve cover and noticed one of the rubber elbows that connects to a vacuum switch was almost rotted through. The boot is connected to a sensor on the manifold, its the first sensor on the manifold closest to the front end. I siliconed it untill I can get a replacement. Still need to figure out what sensor it is to get a new boot for it.
I will check all the lines connecting to the throttle body. I noticed that it looks like my injectors are leaking because of the dirt ring around where they connect to the motor. I was thinking of replacing those too w/ 2.4l neon injectors. Could those cause the rich mixture
