Help with my 1st Jeep build! - JeepForum.com
post #1 of 8 Old 11-14-2008, 06:26 PM Thread Starter
BeLIEve
1990 XJ Cherokee
Hey everyone, I posted an intro thread in the Registry with a bunch of pics of my 1st Jeep. I'm really excited to get started on a solid build, as a former Army Medic and a current SAR/Paramedic student, I'd like to make my build as functional as possible for work purposes. I'm starting to put together a list, and I've already made friends with the counter drones and manager at my local auto parts store. (Lucky for me it's right across the street.)
I need to clean it up a little bit and fix a few important things before I move on to mods.
http://www.jeepforum.com/forum/f22/did-i-get-good-deal-my-first-jeep-631853/
That's the pics and description.
So here's my list I just made:
-Fix Electrical Issues (Priority)
-These are many and major. If I wasn't a shadetree trying to get to know my vehicle extremely well, I'd just drop it off at a shop, but I figure it's better to blow an extra day or two of "get to know you time" even if it's less than efficient.
-Front Parking light is out. With a test light, I get power to both connections in the socket. When I turn the left indicator on it stays solid (no blinking) as long as the headlights are OFF. If I turn the headlights ON, no lights in the front indicator or parking light.
-No reverse lights at all.
-Seat Belt chime makes a sound like a demon from the bowels of hell.
-No horn.
-Aux Fan Relay is bad. (On 3 day backorder)
-Various interior bulbs, decklights.
Fix air induction hose?
-New tires. (I have about a $600 budget for this and I am looking to buy them this weekend.)
-Replace broken Driver Window and Driver Rear Glass
-Fix Ignition Bezel
-Replace radio
-Replace Foglights See a pattern developing here?
-Remove bumpercaps and fender flairs. Unsure of what to do beyond that. Maybe Krylon and put them back on?
-Remove rear seats and carpet, and bedline the interior I have a SAR K9 and need to install a Kennel in the rear.
Upgrades involve a 6" lift, Kevlar panels in the doors and liftgate, MDT mounts, longarm rack, rock lights, wigwags/whaler, QBeams, upgraded alternator/gel cell battery, power converter, GPS, lockboxes, undercarriage spare tire mount, roll cage and some classes for myself in Offroading and Trail Repair.
Any advice on current issues (especially the electrical) and future upgrades would be much appreciated. I'm in school full time to be a Paramedic here in Oregon, and plan to spend WAY TOO MUCH TIME doing this.
Thank in advance for all the help. This site is an amazing resource and I will be more than happy to contribute financially next Thursday. (Tuition+Kids=fun...!)
Anger ruins joy. Steals the goodness of my mind. Forces my mouth to say terrible things. Overcoming anger brings peace of mind. Leads to a mind without regrets. If I overcome anger, I will be delightful and loved by everyone.
BeLIEve is offline
post #2 of 8 Old 11-14-2008, 06:59 PM
Whackmaster
For the electric issues I would check and see if you have an aftermarket trailer wiring harness....If those are wired improperly they will give you electric issues....Something to check. Good Luck
Whackmaster is offline
post #3 of 8 Old 11-14-2008, 07:34 PM
BayouBengal85
under carriage spare mount?
as far as i know, there's no way (or room for that matter) to mount a spare tire under an xj. i may be wrong, but never heard of or seen it done. if you have seen it and have pics please post cuz i would love to see it
BTW, not trying to be a smart a$$
96 2wd XJ Sport, 4dr, 4.0HO, Auto, 3.55 gears,117k Miles
15x8 Canyon Rims
31x10.50x15 TreadWright Warden AT's
Fram Air Hog Filter
Magnaflow Hi Flow Catalytic Converter
Dynomax Superturbo Catback Exhaust
BayouBengal85 is offline
post #4 of 8 Old 11-14-2008, 07:44 PM
BayouBengal85
damn double post, my bad
15x8 Canyon Rims
Fram Air Hog Filter
post #5 of 8 Old 11-14-2008, 08:06 PM
Steamer98
Steamer98's Avatar
Ambitious list!
As you get more familiar with your XJ and these forums some things will change as far as what you want to do. Take your time...
Like the 6" lift, thats about as high as any XJ needs to be, and many mod$ come with that height for a reliable rig that can be very expensive to do all at once. The fun is in building and learning, things will grow as time/budget progresses. Start with your basic issues, then move on to recovery, and armor.
98 XJ Limited
Stock XJ tire carrier for sale
Steamer98 is offline
post #6 of 8 Old 11-14-2008, 08:53 PM
BayouBengal85
sorry about the triple post, internet connections been acting up and i didn't realize it submitted more than once
15x8 Canyon Rims
Fram Air Hog Filter
post #7 of 8 Old 11-14-2008, 09:47 PM
92XJCowboy
If you have a K9 unit I would only go with a 4.5 inch just to make it easier on the pup. Yes I know that most can jump that high but why make them do it when they dont have to.
I have worked with the K9 units when training with my fire department and they are awesome dogs in every way.
If it rolls, floats, flies or shoots, runs on gasoline or gunpowder, goes fast or shoots a big bullet and makes lots of noise, thus producing torque and recoil its cool.
92XJCowboy is offline
post #8 of 8 Old 11-14-2008, 10:15 PM
Tarukai
For your parking lamps and reverse I know what the problems will probably be.
Reverse is more than likely the NSS (Neutral Safety Switch), which is on the side of your AW4. That you will have to remove and clean, which should fix your reverse lights in a cinch. the Write-up I used is the Jeepin.com one seen here, and this project should take you maybe 2-3 hours at the most (extreme most, I'd say).
Now, for your parking lamps, my friend's old 94 Ciera had this problem at times. With your fuses you should have two silver/cylindrical looking things, and I believe one is a parking lamp fuse/relay (I forget which), and that may be bad or a bit out of whack. With his, they replaced it and it worked for a while. Then it started to act up again (this was when I was driving it), and they removed it, looked at it, and it looked fine. So they put it back in, and it worked fine again. Mind you, I'm not sure on this advice, but check a manual if you can to make sure that's how the lamps operate with the fuses.
That's all I've got for now, and good luck!
Tarukai is offline
my jeep build great-white XJ Cherokee Technical Forum 19 07-24-2009 10:52 PM
new jeep build great-white XJ Cherokee Technical Forum 4 07-24-2009 01:24 PM
my jeep build jetwrench XJ Cherokee Technical Forum 9 03-12-2008 01:01 PM
Jeep Build Tlong80 XJ Cherokee Technical Forum 2 10-24-2007 08:26 PM
First Jeep Build Tlong80 MJ Comanche Technical Forum 3 10-24-2007 06:30 PM
