HELP! misfire gremlin - Page 2 - JeepForum.com
post #16 of 24 Old 01-03-2013, 02:21 PM Thread Starter
Kali01
well. finally got a hold of the shop and low and behold they've already bypassed the return/ground with no luck.
mechanic says he's "chasing his own damn tail" and that i can "drive through the problem". needless to say i just fired my second mechanic.
back to the drawing board.
Kali01 is offline
post #17 of 24 Old 01-03-2013, 04:48 PM
GetLifted
My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
Seriously. If only you were closer. I want to take a crack at it.
GetLifted is offline
post #18 of 24 Old 01-04-2013, 05:20 PM Thread Starter
Kali01
Ugh, I wish... if it weren't my daily driver it wouldn't be such a problem. It's been in the shop 3 weeks now, classes start next Tuesday and I literally have no way to get there. sadly, i'm desperate :/
Kali01 is offline
post #19 of 24 Old 01-04-2013, 10:06 PM
bobbo_xj
compare similar symptoms here http://www.jeepforum.com/forum/f11/n...00-xj-1391464/
a weak exhaust valve spring(s) apparently was the troublemaker.
2001 XJ Sport, 173k mi.
bobbo_xj is offline
post #20 of 24 Old 01-05-2013, 10:21 PM
tcullen07
Just blow it up! Haha
tcullen07 is offline
post #21 of 24 Old 01-06-2013, 01:43 PM Thread Starter
Kali01
You know Damn well I'm not going blow it up Tim. :P
Kali01 is offline
post #22 of 24 Old 01-06-2013, 01:55 PM
tcullen07
I hope you don't. Conferred w jeep fried in Cali and he said "Timing or need a new map sensor." Hope that helps.
post #23 of 24 Old 01-19-2013, 06:36 AM Thread Starter
Kali01
The guys at happy trails changed the map sensor and put the old computer back in, Ran for 3 days. Turned it on this morning and the CEL was flashing... I'm just going to unplug the ecu every three days...
Kali01 is offline
post #24 of 24 Old 02-12-2013, 08:19 PM Thread Starter
Kali01
Just as an update; I finally got time to chase the problem down. First I narrowed the wiring problem down by unplugging the pcm one cluster ay a time. Turned out the problem originates in something that plugs into p1. From there I unwrapped and followed the wires till I found the problem... which was.... wait for it.... A PINCHED WIRE!!!!!!!!!
Haven't had any problems since. I paid around 2000 $ for three shops to tell me I was sol and fixed it in literally 5 minutes.
Kali01 is offline
flashing cel , misfire , rough start
