HELP! misfire gremlin - JeepForum.com
post #1 of 24 Old 12-28-2012, 09:11 PM Thread Starter
Kali01
I've been chasing a gremlin in my 2001 Jeep Cherokee for almost 6 months now. symptoms are as follows:
-on a cold start it'll run like hammered ***. CEL flashes, multiple cylinder misfire (always cyl. 3 and others are randomly dropped) up to 3 at one time.
-if you let it get to running temp (it can't just idle I've tried; you have to actually drive it) turn it off for 2 minutes and turn it back on she runs like a completely different vehicle. CEL is still on but not flashing, idles a little rough but not bad enough for anyone but myself to notice.
-as long as the engine doesn't cool completely she'll run fine for the rest of the day.
list of things i've already tried to avail:
-new plugs, all NGK
-new injectors (they were old anyway. i figured why not?)
-new coil pack
-new ECM
-new crankshaft position sensor
- i have a heat shield on cyl. 3/manifold/fuel rail.
compression tests check out fine. noid test on injector wires are fine. I really don't want to sell but i might have to if i can't figure this out.
just put in a remaned long block in june. does anyone have any ideas?
Kali01 is offline
post #2 of 24 Old 12-28-2012, 09:15 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Check out the TSB in my thread. It has solved issues on 2 Jeeps in my shop.
http://www.jeepforum.com/forum/f310/...issue-1450392/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 24 Old 12-28-2012, 09:21 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Kali01 View Post
....... just put in a remaned long block ..........
Check the cam sensor synchronization.
Read this -> http://jeep.blackonyx.net/pdfs/jcss.pdf
CJ7-Tim is offline
post #4 of 24 Old 12-28-2012, 09:22 PM Thread Starter
Kali01
my problem is pretty much the complete opposite. once the engine is warm it runs fine, only when it's cold does it throw fits.
and unfortunately i already have a heat shield
Kali01 is offline
post #5 of 24 Old 12-28-2012, 09:22 PM
Tkoffroad
Have the same problem except mine is cylinders 6
2001 60th anniversary edition Jeep Wrangler 33 inch General Grabber AT2 Spectre cold air intake
Tkoffroad is offline
post #6 of 24 Old 12-28-2012, 09:32 PM Thread Starter
Kali01
that was extremely helpful. i'll have to suggest that to my mechanic. thank you
Kali01 is offline
post #7 of 24 Old 12-29-2012, 11:09 AM Thread Starter
Kali01
still no luck. someone suggested that a relay from the computer to the injectors could be bad.
i didn't even think about it being an electrical issue. sound plausible?
Kali01 is offline
post #8 of 24 Old 12-29-2012, 11:17 AM
buildin1XJ
What are the exact codes you have now?
buildin1XJ is offline
post #9 of 24 Old 12-29-2012, 12:35 PM
GetLifted
Mine was very similar. It was electrical. I discovered the problem on page 3 and 1000$ later...
http://www.jeepforum.com/forum/f11/w...45/?highlight=
GetLifted is offline
post #10 of 24 Old 12-29-2012, 06:38 PM Thread Starter
Kali01
so basically i need to check the grounds around the crankshaft position sensor and while i'm at it check the other grounds as well. i read the whole thread, found myself laughing when you said you were praying for a blown head gasket too... if only it were that simple. :/
Kali01 is offline
post #11 of 24 Old 12-29-2012, 07:00 PM
GetLifted
Not really a "ground" to check, but the resistance in the wires from the PCM connector to the cam and crank sensors. The sensors don't chassis ground, they are a return signal to the PCM.
post #12 of 24 Old 12-29-2012, 07:08 PM Thread Starter
Kali01
also, i would like to reiterate that the problem isn't with hot starts; once it's at 210 she'll run all day. only at a cold start like after sitting over night will the gremlin rear it's ugly head and then once it reaches running temp you can turn it off let it sit for a couple minutes turn it back on and she runs fine.
only PO300 codes are being thrown.
i have tried everything i know how to do and have had it seen by two shops. she's with a jeep specialist (worked for chrysler for 20 something years/jeep enthusiast) and he's coming up empty handed too.
it's got to be something small, something i'm overlooking, electrical most likely. but where?!?!?!?!
Kali01 is offline
post #13 of 24 Old 12-29-2012, 08:19 PM
GetLifted
To test the harness:
Unplug the PCM c1 connector. Unplug the cam AND crank connector plugs at the sensors. Use a multimeter set to 0-10k ohms resistance. Probe the PCM C1 PIN4 HOLE (black/blue stripe) with one end of the meter, with the other end of thr meter probe the black/blue stripe wire at the cam and crank sensor and MAKE SURE it's zero ohms (they share a sensor return/ground).
You can use this procedure for any part of the harness. T-pins fit in the PCM connector holes perfectly. Alligator clips snap on to the pin. It's explained in the thread I posted with pictures.
post #14 of 24 Old 12-29-2012, 11:27 PM
mmcc
I had a missfire in mine a little ways back. My buddies and I evenualy pulled a cam position sensor of his jeep and we replaced the platinum spark plugs with cheaper copper ones. The jeep ran great after that. I know plugs sound crazy, but its a cheep enought thing to just through a couple of bucks
at and pray it works. My .02.
mmcc is offline
post #15 of 24 Old 12-30-2012, 07:59 AM Thread Starter
Kali01
You can use this lrofedure for any part of the harness. T-pins fit in the PCM connector holes perfectly. Alligator clips snap on to the pin. It's explained in the thread I posted with pictures.
thank you so much! only problem is the shop won't open again till wednesday due to new years :/ ugh... patience is a virtue i was not blessed with
thanks to everyone who tried to help. i'll post updates when i know something.
Kali01 is offline
flashing cel , misfire , rough start
