HELP!!! losing antifreeze and can't find where. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > HELP!!! losing antifreeze and can't find where.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-05-2012, 07:58 PM   #1
matt2000xj
To start off; I have a 2000 Jeep Cherokee classic with the 4.0 I6, with 130,000 miles, and I'm very aware of the 2000 model year head casting issues between cylinders 3 and 4, and I have not pulled the valve cover YET to verify if there is in fact a crack. But from all other ways to tell, i do not have a coolant leak anywhere internal or external. no antifreeze in oil or steam from the tail pipe. once every week or two weeks i have to add almost a gallon of antifreeze. I am stumped. my main concern is my oil cap has a milky substance from what i think is condensation.
Also there is some sort of stop leak in the cooling system from the p.o.
Any ideas or advice would be greatly appreciated.
Thanks in advance,
matt2000xj
matt2000xj is offline   Reply With Quote Quick reply to this message
Unread 12-05-2012, 08:43 PM   #2
MGrobe
Man In Black
MGrobe's Avatar
Note to OP, thread was moved to Cherokee Tech...
-Marc-
Sweet Pea 1998 - XJ
http://www.grobe.us/Jeep
- JeepForum Rules - Become a Premium Member or Vendor
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline   Reply With Quote Quick reply to this message
Unread 12-05-2012, 08:48 PM   #3
Tdog02
Change your oil and see if you have mocha colored oil. With that much fluid in it you should see some leak from the rear main if head is cracked. Honestly you may not even notice the crack if you don't know what to look for. Mine was very difficult to see.
That's the crack in mine. Because it was a small leak I never developed the milky cap. Mine looked like miles of rust in radiator. Odd thing is she ran very good.
it is what it is except when its something else
Tdog02 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2012, 11:36 PM   #4
MCrock
I think that the milky substance on your oil cap is your answer..
-Mark
MCrock is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 03:22 AM   #5
Bbasso
stop using the XJ til you get it properly diagnosed.
Bbasso is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 06:49 AM   #6
Kalali
All your symptoms are pointing to a cracked head. Measure your oil when drain it next time and you'll see some of the missing coolant. Replace the head before putting any more miles on the engine. The antifreeze will toast the lower end bearings faster than you think...
Kalali is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 09:05 AM   #7
matt2000xj
Its my only vehicle, i have to drive it
Unread 12-06-2012, 11:05 AM   #8
tjwalker
It's the crank sensor!
tjwalker's Avatar
If it is a cracked head, which is very likely, the more you drive it the more damage you are doing to the bearings inside the engine.
If caught early enough, sometimes you can get by with a new head and a few oil changes. If not caught early, it's time for a rebuild or a different engine.
The stop leak that the previous owner put in is most likely because he/she couldn't find the coolant leak either and thought the stop leak might help. It won't .
Get the valve cover off and get a look with a good light. You need a proper diagnosis and oftentimes you can see the crack with the naked eye.
Let us know what you find.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 02:22 PM   #9
sAe23
1995 XJ Cherokee
Estimate the cost of renting a car while you get the top end fixed vs the cost of renting a car while you REPLACE THE WHOLE ENGINE...
Hope
That
Helps
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 03:36 PM   #10
Millermagic
If it's a milky oil cap ... the head is cracked.
For what it's worth, for a period of a few months, I did a lot of short trips in my Cherokee. Ranging from hot days to damp days to freezing winter days. Never once did I get a milkshake on the oil cap. Some vehicles, by nature, will get the milky oil cap (ford's mod v8s) ... jeep 4.0s generally won't get it with short trips.
And, if they run hot enough, that they'll burn off any normal moisture as soon as they heat up.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 04:04 PM   #11
DoctorTim
if you dont have a cracked head, your freeze plugs could be leaking.
http://www.jeepforum.com/forum/f11/96-xj-build-hybrid-1311863/
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline   Reply With Quote Quick reply to this message
Unread 12-06-2012, 04:14 PM   #12
Millermagic
He'd be able to see / smell it right?
Unread 12-06-2012, 04:38 PM   #13
DoctorTim
it is quite difficult to spot, its a very cramped area. you might be able to smell it but it usually blends in with other smells that come from you motor. I found mine using a flashlight and one of those little mirror-on-a-stick that dentists use. but if you're losing a large amount of fluid, then you should notice it on the garage floor.
Unread 12-06-2012, 06:07 PM   #14
Jeepnbo
you have a cracked head. Brothers 2000 xj had the same symptoms. Using coolant, no leaks and still ran great. Replaced the head and it hasnt used coolant at all. Caught it quick enough. bite the bullet and replace your head
Jeepnbo is offline   Reply With Quote Quick reply to this message
Unread 12-07-2012, 12:07 AM   #15
matt2000xj
I do work for orielly auto parts, so the head will only run me about $370 + head bolt set $35 + head gasket set $100 +/-. Now i haven't pulled the valve cover yet, and my jeep is a late 2000 model year i think. So if i just happen to have the (0331) casting; then what else could it be?
