HELP!!! Ignition wont turn - JeepForum.com
post #1 of 20 Old 03-10-2007, 05:12 PM Thread Starter
BlacknRedGT
My g/f has a 2001 Cherokee Sport and her ignition wont turn either way. Tried moving the steering wheel to get it to go and now the steering wheel is locked and wont move at all. Made sure it was in Park and the normal crap. Her car has a weird light with a button at the bottom below the steering wheel underneath the dash for the alarm. Not sure if its aftermarket or what but the lock and unlock button has a jeep logo on so Im assuming its stock....
What do you guys think it is??
Anyway to bypass the alarm all together to make sure thats not it?? Like pull a fuse or just cut a wire??
What else could it be??
BlacknRedGT is offline
post #2 of 20 Old 03-10-2007, 08:04 PM Thread Starter
BlacknRedGT
Bump...................
post #3 of 20 Old 03-10-2007, 08:08 PM
XposedGuts
i did this today from moving the wheel when the car was off(was working under the car and needed to move the wheels). Anyway just jurk the wheel and key at the same time
XposedGuts is offline
post #4 of 20 Old 03-10-2007, 08:10 PM Thread Starter
BlacknRedGT
Doesnt work... I would have to break the column to get the wheel to move. Believe me... Tried that a million times already
post #5 of 20 Old 03-10-2007, 08:11 PM
XposedGuts
dont start cutting wires or fuses trust me. man handle it u just need the right touch
post #6 of 20 Old 03-10-2007, 08:34 PM Thread Starter
BlacknRedGT
2 guys pulling on the steering wheel wasnt enough.... I have broke steering columns before and dont want to do that... The ignition key wasnt turning even when the wheel was free... I told my ex to move it around and try it. The wheel then locked up. Theres something else going on here.
Not just the wheel being locked. The key is not turning in the ignition either way,
post #7 of 20 Old 03-10-2007, 08:42 PM
XposedGuts
so the wheels not turning or the key in the ignition? cause thats exactly what the car does when the wheel is turned to much if the car is off. Happened to me today
post #8 of 20 Old 03-10-2007, 08:56 PM Thread Starter
BlacknRedGT
The wheel doesnt turn and the key in the ignition doesnt turn.... Tried moving both around at the same time and the car doesnt start. Car is in park etc etc. The key in the ignition wouldnt turn even prior to the wheel being locked. doesnt look like anything is wrong with the ignition so I was wondering if maybe it had something to do with the alarm.
post #9 of 20 Old 03-10-2007, 09:11 PM
tangofox007
You might try pushing the gear selector forward while trying the ignition switch at the same time.
tangofox007 is offline
post #10 of 20 Old 03-10-2007, 09:15 PM
tangofox007
I can't even get my wife to help me work on her car. And here you have your ex working on your girlfriend's Jeep!!! That's impressive.
post #11 of 20 Old 03-10-2007, 09:19 PM Thread Starter
BlacknRedGT
Ill try the gear selector thing... I tried moving around too but not holding it forward. ohh and the g/f is really my ex.. she likes to call when she needs things. I only work on porsche 944's so I dont know jack about jeeps.
post #12 of 20 Old 03-10-2007, 09:23 PM Thread Starter
BlacknRedGT
anyone else with a idea?? How do I bypass the alarm system to make sure thats not the cause.
post #13 of 20 Old 03-10-2007, 10:10 PM
mdjeep96
Sounds like an alarm system. I had a 95 mustang and when I first got it I didnt know how the alarm worked it was factory remote but aftermarket stuff. Look for a switch to press or press unlock 2-3 times with the remote till it chirps. Thats just my 2cents though good luck.
mdjeep96 is offline
post #14 of 20 Old 03-10-2007, 10:22 PM Thread Starter
BlacknRedGT
Ya it doesnt sound like its factory but I guess it uses the factory buttons..... Ill try pressing that button a couple of times too
post #15 of 20 Old 03-12-2007, 01:05 PM Thread Starter
BlacknRedGT
hey, none of this stuff worked??? what else can i try??
ignition switch wont turn how to remove and question bcameron1974 XJ Cherokee Technical Forum 7 01-30-2010 04:02 PM
Key wont turn in the ignition cylinder fitbmxseries1 XJ Cherokee Technical Forum 15 01-14-2010 08:41 PM
key wont turn in ignition, 93xj. problems bughunter XJ Cherokee Technical Forum 1 04-13-2009 09:34 AM
Key wont turn in ignition, cannot get cylinder out Tommyboy75861 XJ Cherokee Technical Forum 3 12-07-2008 06:47 PM
Key wont turn in ignition tangofox007 XJ Cherokee Technical Forum 9 08-30-2007 02:57 PM
