Help with headlights!!! - JeepForum.com
 1Likes
post #1 of 42 Old 09-11-2016, 09:30 PM Thread Starter
99CherokeeS
I have a 1999 Jeep Cherokee Sport and the sealed beam headlights are still on it. I am thinking about switching them out. Suggestions?
99CherokeeS is offline
post #2 of 42 Old 09-12-2016, 07:35 AM
art247
I have got a 2000 xj jeep cherokee with the same issue hopefully someone will tead this post
Sent from my SM-G900P using Tapatalk
art247 is offline
post #3 of 42 Old 09-12-2016, 07:53 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use E-code halogen 100% glass housings and white H-4 bulbs. Anything car show cool or Ricer style will be Chinese garbage. You should also upgrade the headlight wire harness for maximum performance.
CJ7-Tim is offline
post #4 of 42 Old 09-12-2016, 09:07 AM
75SV1
I have AutoPals. Good Quality, Low price. I used there bulbs that came with them. About twice as bright as the sealed beams. I have not done the wiring harness. Plan to. Also, haven't upgraded to 'better' bulbs. My experience with the 'better' bulbs, is they will burn out quicker. So keep an extra set or regular set with you. This was on an '81 MB 240D. I do have the Autopals on my XJ. The MB has a Cibie and a Hella, but used. I did have on new Sealed Beam on the XJ to compore to.
75SV1 is offline
post #5 of 42 Old 09-12-2016, 07:11 PM Thread Starter
99CherokeeS
@CJ7-Tim Is it difficult to switch from sealed beams to the halogens? Is it something I could do myself?
post #6 of 42 Old 09-12-2016, 09:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
simple.
DO NOT do this without upgrading your harness!!!
http://www.cherokeeforum.com/f51/hd-...rite-up-11306/
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 42 Old 09-13-2016, 12:30 AM
BagusJeep
1981 CJ7
Best mod on an XJ IMHO is to do the headlight relay upgrade. Adds about 1 Volt at the lights which is A LOT in terms of light.
The dipped beams will be so much better, clearer cutoffs.
The high beams you could install some driving lights, they will throw light much further forwards in a narrower beam than the headlights,
XJFoxxx likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 42 Old 09-13-2016, 06:40 AM
Berti
I'm using E code Depo 100-1120N-LD-E clear headlights, with Pegasus HOD H4 bulb. Super bright and white, would recommend this combination for everyone. Relay upgrade also done.
Berti is offline
post #9 of 42 Old 09-13-2016, 07:11 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You know, on one of the many Jeep forums I frequent, there was a guy who tested stock headlights with a lumen meter before and after the harness ONLY.
35% improvement in output after the harness.
post #10 of 42 Old 09-14-2016, 10:50 PM
PimaXJ
1997 XJ Cherokee
This makes it pretty clear: http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm It basically follows the same format as building a fog lamp wiring harness but with two relays, one for low beam & one for high. Heavier wire plus relays will make all of the difference. This fuse block will reduce the number of splices by eliminating the inline fuses.
https://www.delcity.net/store/ATC-&-...2.h_811763.t_1
Cibie lamps are recommended & 65/75 watt bulbs. Will consider going up to 65/100 watt bulbs. The new wiring harness will handle it.
PimaXJ is offline
post #11 of 42 Old 09-15-2016, 11:02 AM
xjshellback
I have the LED ones and they are much better. have the 100 watt ones in my garage if anyone wants them.
08 WK 2in lift 265/70/17 3.7L
10 JKU Sahara 3in lift 35X12.5R18
xjshellback is offline
post #12 of 42 Old 09-15-2016, 04:41 PM
mschi772
1997 XJ Cherokee
Ahem. http://www.jeepforum.com/forum/f11/headlights-2891137/
PLEEEEASE read it. I put so much work into it, and you'll learn so much.
From my writeup linked above that not enough people read. Not implying that you didn't, Cruiser, cuz I know you did. Like your stuff, just not enough people find it and read it.
Originally Posted by mschi772 View Post
...... A 10% drop in voltage (a little more than 1 volt) reduces headlight output to 2/3 of its maximum potential! ......
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #13 of 42 Old 09-16-2016, 08:29 AM
bryanintowson
1992 XJ Cherokee
Installed this harness:
http://www.ebay.com/itm/H4-Headlight...lXehfq&vxp=mtr
along with a set of Hella H4 housings and bulbs. Very pleased with the results. Just make sure when you are doing the install to route everything well and to make sure that you have a good ground otherwise you will get one dim side and one bright one. I ended up grounding to the radiator mount which required some light sanding.
1992 Cherokee Laredo - Current
2002 Wrangler Sport - SOLD
bryanintowson is offline
post #14 of 42 Old 01-31-2017, 06:52 PM
TomFoolery
hey everyone. i spent a lot of time reading around and have read these threads many times (thanks for posting those instructions!).
i have weak headlights that are dim on my 98 xj sport.
i sprayed contact cleaner on the leads and brushed everything. i also restored the halogen lamps to make sure they are clean.
i tried aiming but i have to try that again.
i understand you cannot just put stronger lamps in because that might burn out.
i checked how much voltage im losing at the leads. 2.5 volts, which brings me over the 10% figure quoted above.
i know the stock wiring is crap and i have to upgrade harnesses and all that. it just seems like its out of reach for someone with my auto repair skills.
if i bought the right harness- anyone have an idea what the labor is for a mechanic to rewire? im expecting a # that makes me want to do it myself.
TomFoolery is offline
post #15 of 42 Old 01-31-2017, 07:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Super easy. Do it yourself.
