Quantcast Help!!! Head Removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Help!!! Head Removal
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 05-16-2009, 01:38 PM   #1
Ac1d
Started pulling the motor apart last night in order to replace a blown exhaust/intake gasket. Once I get everything apart I see that the rear lower bolt (against the firewall) is broken off in the head. So I head to the auto-parts store this morning picked up a new head gasket and valve cover gasket. Since pulling the head out is the only way that I can get to the stupid thing. Everything has gone pretty smooth thus far. Just need to know if there is a specific de-torque sequence for removing the head bolts. Also is there a specific order that they need to be removed in.
Any help would be greatly appreciated.
Ac1d is offline   Reply With Quote
Old 05-16-2009, 01:50 PM   #2
HankyDanky
1989 XJ Cherokee
Not for removing but you need to keep all of the rockers and rods in order! And put them back where you took them out. There is a spec torque for reinstalling and bolt tightening sequence though. Give me a mintue and I will get pic's out of my manual for you.
1989 Cherokee 4.0l, Rubicon Express 4.5" XJ Super-Flex System, 33x12.50x15 KM2's, Mustang 5.0 19lb injectors, Sanden OBA Setup, 96 MC/Brake booster, Flowmaster Super 44 Exhaust, Magna Flow Cat, Custom Safari Roof Rack, Diamond Plate Armor, Uniden 520XL CB/PA w/ FireStick Antenna.
My XJ Build - http://www.jeepforum.com/forum/f22/1989-cherokee-xj-build-598549/#post5617067
People are always grabbing the handles, clutching the seat, or stomping an imaginary brake peddle when we're out having fun.
Night Crew #165
HankyDanky is offline   Reply With Quote
Old 05-16-2009, 01:56 PM   #3
Ac1d
Yeah, I put all of the rockers and bolts in bags and labeled them after I did each one. Then did the good old cardboard trick for the rods.
Old 05-16-2009, 01:56 PM   #4
HankyDanky
1989 XJ Cherokee
http://jeephorizons.com/tech/99_40l_torque_specs.html For specs
My XJ Build - http://www.jeepforum.com/forum/showthread.php?p=5617067#post5617067
Night Crew #165
Old 05-16-2009, 05:29 PM   #5
Ac1d
It says the torque specs are 100ft lbs. for bolt #11 and 110ft lbs. for all the other bolts. I'm wondering if I have to tighten it to lets say 22ft lbs. on each bolt, then 45lbs and do a final tightening to 110ft lbs.. Also I'm having trouble figuring out which bolt is #11, from the diagram it looks like the front drivers side, but I'm really not sure.
Old 05-16-2009, 05:42 PM   #6
Saudade
1988 XJ Cherokee
What year is it?
Yes, it's a good practice to "walk" the torque up so the gasket gets evenly compressed.
There are also specific torque values and sequence for the manifold. If you need that too, let us know (that's why I asked the year.).
Saudade is offline   Reply With Quote
Old 05-16-2009, 06:11 PM   #7
HankyDanky
1989 XJ Cherokee
Walk it up if it makes you feel better. The arrrow in the diagrahm is bolt number 11. Front drivers side
Night Crew #165
Old 05-16-2009, 07:31 PM   #8
Ac1d
Alright, 2 broken drill bits and a snapped bolt extractor later the snapped off bolt is out. Now for the fun part before putting the head back in. There's a nice orange residue left on the bottom of the head and the top of the block from the head gasket. Any ideas on cleaning the surfaces? There's also a bit of carbon buildup on the top of the pistons and the head where the valves are. Should I bother cleaning this or is it fine to just leave be? and what would you guys recommend for cleaning it. Oh, almost forgot, my rig is an 89.
Old 05-16-2009, 07:53 PM   #9
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
You will have to thouroughly clean the head and block surfaces if you want the gasket to seal. I use a gasket scraper, but a putty knife should work. Be sure to not get any of the material in the water jackets or bolt holes. The number 11 bolt will need some sealant on it.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 05-17-2009, 12:27 AM   #10
Ac1d
Alright, all cleaned up and ready to install. Now is where I'm really in trouble, the manual says to use perfect sealer on the head gasket. Only problem is auto-parts store closed at 10pm. Luckily I had some forethought and bought two types of gasket sealant. First is a high temp (650F) silicon rtv style. Second is called copper spray a gasket, high temp. gasket sealant.
Which one do I use? And more importantly where?
The guy at the auto store was telling me that there is only a couple of small area's on the head gasket that need the sealant. Anyone know where these areas are, or even better have a diagram.
Old 05-17-2009, 12:41 AM   #11
Ac1d
Great to add to my confusion I just checked the gasket, from felpro. It saying printoseal, basically it looks like there's already small (1/16") beads of sealant around the cooling jackets and the whole outside edge. Also it says use no sealer. I really don't want to wait till the morning to go in and ask, any one on here know weather I should use the sealant or not. Considering the gasket itself says not to.
Old 05-17-2009, 02:21 AM   #12
diskman_1
1992 XJ Cherokee
I have always put the "Print-o-seals" on plain. Make very sure you clean all the mating surfaces with just laquer thinner or carb cleaner followed by brake cleaner and a clean paper towel. Make sure all the metal surfaces "squeak" when rubbed. Enjoy finding all those little cuts and hangnails that you didn't know you had. I guarantee that the gasket will "stick" very well and seal perfectly.
diskman_1 is offline   Reply With Quote
Old 05-17-2009, 09:48 AM   #13
Ac1d
Thanks again for the info, I tend to be a worry a bit when it comes to working on the internals of my motor. Anything else I don't think twice about, just haven't worked on the internals much.
Old 05-17-2009, 09:54 AM   #14
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Good luck and let us know how it goes.
Old 05-25-2009, 09:33 AM   #15
Ac1d
Sorry haven't been able to post all of last week been a bit busy. I wasn't able to get the project complete. But should be done today. Have the head on and bolted down. Just need to go from there, shouldn't take long though. Just a couple of questions first.
What are the torque specs for the rocker arms?
And second, I've heard you have to burp the coolant when removing a good amount of it. How the heck do you do this? Or do you just top off the system and make sure there's plenty in the overflow bottle?
Glock Forum
