Help hard time starting 89 Jeep Cherokee after drive - JeepForum.com
post #1 of 7 Old 10-23-2010, 02:50 PM Thread Starter
Tintman
I need your help! This doesnt happen every time, but after driving for 10 mins or more and say I stop for gas it wont start up again. Its cranking and cranking but no go. If I wait a few mins sometimes it will start. some times it wont start for an hour.I cheaked and I have fuel pressure. Any ideas? Please help me out.
JEEP
Power is nothing with out control
Tintman is offline
post #2 of 7 Old 10-23-2010, 04:18 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would test the coil while it is in the no start condition. They are prone to thermal failure. Also test the CPS when the condition occurs.
xjfever is offline
post #3 of 7 Old 10-23-2010, 04:28 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I agree that the crank sensor and the ignition coil are the top two components prone to thermal (heat related) failure.
IF your Jeep starts perfectly every time when it is cold, focus on the above two pieces of hardware.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 7 Old 10-23-2010, 04:42 PM Thread Starter
Tintman
Thanks for the qick replys I will check them tommorow and let you know my findings.
JEEP
Tintman is offline
post #5 of 7 Old 10-24-2010, 08:40 PM Thread Starter
Tintman
I replaced the coil pack today and seemed to start quicker but the problem still remains. I will test the cps tonight and get back.
JEEP
Tintman is offline
post #6 of 7 Old 10-24-2010, 09:56 PM
bitbrat
I don't know if this helps... my 2001 has a warm start problem linked to thermal vapor lock .... your title says 89 but your profile says 99.. I would guess on the 89 this wouldn't be relevant as I suspect the injectors/fuel delivery may be different, but I would bet the 99s have that problem too. There is actually a Tech Service Bulletin on it that recommends installing insulators on the injectors to help stop them vapor-locking.....
Thoughts anyone??
Once it starts does it kind of "chug" like it's not really getting enough gas, until you hit the gas a couple of times then it settles down?? That is the symptom on mine...
Andy
bitbrat is offline
post #7 of 7 Old 10-24-2010, 10:05 PM Thread Starter
Tintman
Sorry guys I do have a 99 and just picked up a 89. I am going to order a new CPS tomorrow and see if there is a differance.
JEEP
Tintman is offline
hard time starting Gregg17 XJ Cherokee Technical Forum 4 09-21-2009 06:31 PM
Hard Time Starting. 1984XJ XJ Cherokee Technical Forum 7 06-09-2009 09:29 PM
93 jeep cherokee sport bucking hard starting missing 2beon2wheels XJ Cherokee Technical Forum 4 12-03-2008 04:55 AM
96 Jeep Cherokee - Hard time starting smurfy2313 XJ Cherokee Technical Forum 8 05-28-2008 07:33 AM
Hard starting all the time ChEroKeE1996 XJ Cherokee Technical Forum 10 01-05-2006 07:40 PM
