HELP! Engine suddenly won't turn when key is turned. - JeepForum.com
post #1 of 12 Old 10-16-2013, 05:05 PM Thread Starter
jikarner
My wife and I traded cars for a 95 Cherokee, and found that the cig lighter didn't work and wouldn't charge accessories. I checked the fuses, and they're all good. The existing lighter assembly looked pretty corroded, so I bought a replacement. When I took the old one out, only one wire (black/white) was connected. After unsuccessfully searching the Internet, I tried the only loose wire behind the panel that would fit anywhere on the back of the lighter (purple/white). Now the Jeep won't start. Help!
jikarner is offline
post #2 of 12 Old 10-16-2013, 05:10 PM
psychoteen101
Check your main fuses again. You might have accidently shorted a wire and popped a fuse. Does it turn over? Do any of your interior or exterior lights work?
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #3 of 12 Old 10-16-2013, 06:03 PM Thread Starter
jikarner
Everything else seems normal. Have triple-checked the fuses, and even swapped out the ignition relay. It does not turn over. Checked wiring diagram, and I connected the correct wires for the cig lighter. All lights and radio work.
jikarner is offline
post #4 of 12 Old 10-16-2013, 06:31 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Try starting it in neutral.
***Chris***
chris87xj is online now
post #5 of 12 Old 10-16-2013, 06:55 PM Thread Starter
jikarner
Tried that too. It had an existing issue with that (sometimes wouldn't start in P, would start in N).
jikarner is offline
post #6 of 12 Old 10-16-2013, 07:10 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Sounds like the Neutral Safety Switch was on its last leg and finally died. Your recent electrical work may not be related to the no-start issue.
Here's a good write-up on rebuilding one if you can get it off without breaking its plastic housing. NSS rebuild
If you can get to its connector behind the dipstick, you can put a jumper in as shown below for testing and verification of it not working. This isn't a good workaround fix though because the jeep can start in gear and won't have backup lights without a working NSS.
***Chris***
post #7 of 12 Old 10-16-2013, 09:47 PM Thread Starter
jikarner
I looked at the NSS Rebuild tutorial. Thanks a lot. I think I'll give it a shot.
Hopefully, it was just weird, coincidental timing and not a weird short. I also had the Jeep jacked up to put in a catalytic converter today. Do you think it coming down hard could have done the NSS in?
jikarner is offline
post #8 of 12 Old 10-16-2013, 10:17 PM Thread Starter
jikarner
I'm looking online at NSS's, and am seeing two different parts. There is the larger assembly that bolts to the underside of the transmission, and a small, three-pronged plug/connector. What's the deal?
jikarner is offline
post #9 of 12 Old 10-17-2013, 09:55 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
The switch mounts on the side of the transmission and the electrical connector joins it to the vehicle electrical systems.
Quadratec NSS or Ebay NSS
You'll find the connection point somewhere down behind the dipstick back along the firewall.
***Chris***
post #10 of 12 Old 10-18-2013, 01:12 PM Thread Starter
jikarner
Yeah, sorry. That last post was vague. I was wondering what the difference was between the two types of NSS's. The big, expensive one is for four speed transmissions, like what's pictured in the tutorial.
I just finished rebuilding my NSS following the same steps carefully, and still no start/click. Any other suggestions?
jikarner is offline
post #11 of 12 Old 10-18-2013, 03:35 PM Thread Starter
jikarner
Ok. I tried the rebuild, and nothing. Could you explain the verification technique using a jumper? Do I just stick a wire in the slots and try starting the Jeep?
jikarner is offline
post #12 of 12 Old 10-22-2013, 11:56 AM Thread Starter
jikarner
UPDATE! After rebuilding the NSS and replacing the starter relay and ignition switch, I took it to a shop. The discovered that there is an alarm system installed in the Jeep screwing everything up. $200 to remove it and rewire everything. SUPER!
jikarner is offline
