help??dana 35 pinion nut torque? - JeepForum.com
post #1 of 5 Old 06-12-2008, 06:52 AM Thread Starter
luckypenguin
anyone know?
99 grand cherokee limited, 108k miles, everything stock for now
luckypenguin is offline
post #2 of 5 Old 06-12-2008, 07:02 AM Thread Starter
luckypenguin
yes i did use the search button before posting this
post #3 of 5 Old 06-12-2008, 07:40 AM Thread Starter
luckypenguin
bumpageness
post #4 of 5 Old 06-12-2008, 02:47 PM
89mudlite
2015 JK Wrangler
idk the torque specs on it but mine is tighter than a strait guys butt in a gay bar...i cant break the darn thing loose to replace the seal
bump it up
1989 Cherokee 4.0 4door 4wd 3" rc aal kit, c8.25, custum front bumper, cragar v-5's and 32x11.50 bfg mt's
89mudlite is offline
post #5 of 5 Old 06-13-2008, 04:30 PM
vevalachris
There are no torque specs. Do a search for pinion bearing preload. You will need a new crush sleeve and to tighten you pinion nut so you have 12-14 inch pounds of rotational drag on your pinion.
vevalachris is offline
Help??Dana 30 front pinion nut torque '99RedXJ XJ Cherokee Technical Forum 2 05-09-2015 09:49 AM
Replacing pinion seal on D30 (Pinion preload or regular torque) afguy XJ Cherokee Technical Forum 2 10-06-2008 10:32 AM
Dana 30 Pinion Seal Replacement Torque TMCXJ XJ Cherokee Technical Forum 5 06-25-2007 07:53 PM
Dana 30 high pinion vs low pinion 00xj54 XJ Cherokee Technical Forum 10 04-05-2006 07:47 AM
Pinion nut torque value? Hellspawn XJ Cherokee Technical Forum 0 07-06-2004 06:29 PM
