HELP!!! Coolant boiling in "puke" tank! - JeepForum.com
post #1 of 16 Old 08-10-2011, 08:32 AM Thread Starter
Taylorwoodham
1984 XJ Cherokee
So I've got a weird cooling problem that I can't figure out. I have a 1984 Cherokee and the coolant is boiling in the resovuir tank after a good drive. It's not the thermostat as it has been taken out on the problem persists. My water pump seems to be operational as my coolant has a flow to it. Coolant is at the correct levels. I'm scratching my head on this one and would greatly appreciate any input you guys might have. Thanks in advance for the help.
Taylorwoodham is offline
post #2 of 16 Old 08-10-2011, 10:14 AM
Paradise XJ
1988 MJ Comanche
You need a new cap. Check your bottle for cracks. Burp the system of air.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Ę
Paradise XJ is offline
post #3 of 16 Old 08-10-2011, 12:22 PM
JRT
1988 XJ Cherokee
2nded - I had a similar problem on my 1988 about 2 years ago, and it was a crack in the overflow tank.
That said - I had never seen a "closed" system like this before this car, had never even heard of one, and after much fighting and burping and hose checking and fitting and refitting, I replaced the whole mess. IMHO, that system is a piece of kit best left in the scrapheap. Especially in La, you're probably gonna wanna make a change sooner or later. I hear it gets hot there.
I ended up switching from the pressurized ("closed") burp tank to a recovery / overflow tank and "modern" "open" system using the directions on this site:
http://www.olypen.com/craigh/cooling.htm
(I put open and closed in quotes b/c to my mind, they're backwards as commonly used - but apparently thats how the community understands them. The pre-92 system where the overflow tank has no recovery method and has a pressure cap is "closed" - this is what you describe and what scared the bejebus out of me when I saw it boiling in my XJ. The newer system as found on most other cars in existence ever, where the overflow tank is not pressurized (eg cant boil) and serves as a recovery resevoir, is "open".)
Worked like a champ, and he was right on the money for cost/time/effort even though the page is a bit dated. Cost about $250 and took all day Saturday and half a day Sunday for me and my GF, so not exactly Michael Schumacher's pitcrew.
JRT is offline
post #4 of 16 Old 08-10-2011, 02:36 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If it's an 84 like in the OP's signature, it had a conventional open cooling system with an overflow tank.....
cruiser54 is offline
post #5 of 16 Old 08-10-2011, 06:57 PM
Reptile
1991 XJ Cherokee
Agree with those guys, more likely a bad rad cap. The cap probably doesn't hold the pressure required to lower the coolant's boiling point.
It's not a car it's a JEEP.
Reptile is offline
post #6 of 16 Old 08-10-2011, 06:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep to both statements.
post #7 of 16 Old 08-10-2011, 07:20 PM
djb383
I thought the cap held pressure to increase the coolant's boiling point, no?
djb383 is offline
post #8 of 16 Old 08-10-2011, 07:26 PM
Flyordie
1985 XJ Cherokee
Well, maybe not.
When mine boiled like that it was a bad radiator. Even a new radiator cap didn't solve the problem.
Flyordie is offline
post #9 of 16 Old 08-10-2011, 07:31 PM
Reptile
1991 XJ Cherokee
Right increase it, prevent it from boiling. Got it mixed up.
Reptile is offline
post #10 of 16 Old 08-10-2011, 08:50 PM
djb383
I knew u did.....just funnin' ya.
djb383 is offline
post #11 of 16 Old 08-10-2011, 09:09 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I understood what you meant, too.
Anyway, the OP could have the radiator pressure tested, have the cap pressure tested etc. But, I'd try the cap for $5 first............
post #12 of 16 Old 08-10-2011, 09:18 PM
tangofox007
Some parts stores have pressure testers in their loaner inventory. Put 15 psi in the system and the leaks will reveal themselves promptly. Checks caps as well.
tangofox007 is offline
post #13 of 16 Old 08-10-2011, 09:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That would certainly narrow down the problem.
But, since he mentions no leak other than the recovery bottle catching coolant, I would suspect the cap. That, and they're cheap and certainly don't last forever and are frequently neglected when it comes to maintenance.
It it were me or you, we would most likely go out to the garage and test it with our own pressure tester.
post #14 of 16 Old 08-11-2011, 01:33 AM
BBJeep
1989 XJ Cherokee
Dude put your thermostat back in WTF?
http://www.cherokeetalk.com/forum/members/bigbear/
BBJeep is offline
post #15 of 16 Old 08-12-2011, 09:21 AM Thread Starter
Taylorwoodham
1984 XJ Cherokee
Thanks for all the replies
Alright finally got a day off work so it's time to knock this baby out. Thanks for all the replies. It is an 84 as some of y'all were wondering and there is a new development in the case! There is a BIG hole in the resovuir tank now so that will have to be replaced but anyway, off to snag a radiator cap (preferably with a higher threshold, I believe mine is 14 lbs right now). Thanks again for all the help and I'll let y'all know how it goes
boiling , coolant , overheating , thermostat
Yes, you "can" change the fuel pump on a 1990 Cherokee without droping the tank...BUT alhefner XJ Cherokee Technical Forum 4 07-12-2013 09:00 PM
Overflow tank boiling over. MSH5337 XJ Cherokee Technical Forum 12 01-08-2009 05:28 PM
fuel tank never really gets "full" warrior_oh58d XJ Cherokee Technical Forum 2 12-24-2008 05:40 AM
"Coolant Sensor Bad" jakewalczak XJ Cherokee Technical Forum 2 08-09-2007 11:21 PM
how "fixable" is a factory gas tank skid MPETESS10 XJ Cherokee Technical Forum 3 04-29-2006 06:32 PM
