Help! Anti freeze leak ( not hose) name this part - JeepForum.com
 1Likes
  • 1 Post By bluejunior
post #1 of 12 Old 03-17-2017, 11:32 AM Thread Starter
Scottykenneth
Hey guys so Im driving yesterday. Hear a major squeal. Pull over belt is almost off. And leaking antifreeze everywhere. I pulled the belt off today and this spindle(4bolts) where the arrow is pointing. Leaking a lot behid the spindle. Looks like it can be replaced. Help!
Scottykenneth is offline
post #2 of 12 Old 03-17-2017, 11:49 AM
bluejunior
bluejunior's Avatar
Water pump
blu92in99 likes this.
Lifted, Locked, Stiffened
bluejunior is offline
post #3 of 12 Old 03-17-2017, 12:13 PM Thread Starter
Scottykenneth
Crap. Def leaking. Easy to fix myself?
post #4 of 12 Old 03-17-2017, 12:16 PM Thread Starter
Scottykenneth
Leanking behind the spindle. Def cant fix right? I need a new one? Thanks guys
post #5 of 12 Old 03-17-2017, 12:21 PM
bluejunior
bluejunior's Avatar
Needs replacing. Not a bad fix, just needs basic tools. A new one will run you something like 60-70.
Might need to take out the aux fan and fan shroud to give yourself some room to work, then you just loosen and remove the belt, unbolt the old water pump, bolt the new one one, re-install the belt and anything else you removed for clearance and then replace whatever coolant you lose in the process.
post #6 of 12 Old 03-17-2017, 01:19 PM Thread Starter
Scottykenneth
Thank you!!
post #7 of 12 Old 03-17-2017, 01:29 PM
bluejunior
bluejunior's Avatar
Originally Posted by Scottykenneth View Post
Thank you!!
No problem. I didn't mention this but just in case: there is a gasket between the pump and the engine, you'll need to pick up a new one along with the new pump. Should only be a few bucks but it's important.
post #8 of 12 Old 03-17-2017, 06:12 PM Thread Starter
Scottykenneth
Well changed it all. Now running hot. What ya think? Fixed the leak tho.
post #9 of 12 Old 03-17-2017, 09:52 PM
bluejunior
bluejunior's Avatar
Got all the air out of the system?
post #10 of 12 Old 03-26-2017, 09:58 AM
KF4SQB
1994 XJ Cherokee
Two things to check. First, are you sure that you reinstalled the belt correctly? If it isn't routed correctly, it can turn the pump backward, and it will NOT pump correctly. Second, did you "burp" all the air out of the system when you refilled it? These things are notoriously hard to get all the air purged out of the system. The air pockets will hit the pump, and the pump will stop pumping, as its not designed to pump air. To get the air out, you can either open a hose connection at a high point in the system, or squeeze the upper radiator hose until you stop getting bubbles in the filler neck. Just do a search; there are tons of threads on here on the subject.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #11 of 12 Old 03-27-2017, 08:32 AM
SmashDN
Change thermostat at same time. Might as well, it is right there and only a few more bolts and a seal.
SmashDN is offline
post #12 of 12 Old 03-27-2017, 06:15 PM
desbennett004
Hopefully you put the right pump in. They make them to spin both ways, depending on your belt routing, but other than that they look exactly the same. Might be the cause of your over heating if the impeller is facing the wrong way.
Sent from my SM-N900W8 using Tapatalk
desbennett004 is offline
