HELP! Age old overheating-I'm lost - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > HELP! Age old overheating-I'm lost
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! 07-15 jeep jk flush mount led tail lightsThe Original 3/8" Ruffstuff Diff Cover!
Unread 10-06-2012, 07:26 PM   #46
BlackPearl
It starts there and moves towards the back of the engine about 3/4 to 1 inch. It wasn't pouring out but with the engine hot it bubbles out of the crack.
BlackPearl is offline   Reply With Quote Quick reply to this message
Unread 10-06-2012, 07:50 PM   #47
Pats94
Losing pressure and antifreeze will cause your over heating. I'd see about getting it welded. Don't try to use sealant.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2012, 08:32 PM   #48
Reptile
1991 XJ Cherokee
Yes it will. The cooling system is under pressure. A loss of pressure will lower the coolant's boiling point...
Do you know for sure the crack wasn't there the last time you took out the pump?
Reptile is offline   Reply With Quote Quick reply to this message
Unread 10-06-2012, 09:05 PM   #49
BlackPearl
I don't know if it was there last time I took out the pump. But I took the pump to the parts store and it is in fact the correct pump. I am going to see about getting it welded...but if all else fails maybe a 4.6 stroker swap?????
cooling , issues , overheating
