HELP! Age old overheating-I'm lost - Page 4 - JeepForum.com
post #46 of 49 Old 10-06-2012, 08:26 PM Thread Starter
BlackPearl
It starts there and moves towards the back of the engine about 3/4 to 1 inch. It wasn't pouring out but with the engine hot it bubbles out of the crack.
BlackPearl is offline
post #47 of 49 Old 10-06-2012, 08:50 PM
Pats94
Losing pressure and antifreeze will cause your over heating. I'd see about getting it welded. Don't try to use sealant.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #48 of 49 Old 10-06-2012, 09:32 PM
Reptile
1991 XJ Cherokee
Yes it will. The cooling system is under pressure. A loss of pressure will lower the coolant's boiling point...
Do you know for sure the crack wasn't there the last time you took out the pump?
Reptile is offline
post #49 of 49 Old 10-06-2012, 10:05 PM Thread Starter
BlackPearl
I don't know if it was there last time I took out the pump. But I took the pump to the parts store and it is in fact the correct pump. I am going to see about getting it welded...but if all else fails maybe a 4.6 stroker swap?????
cooling , issues , overheating
Lost pwmach1 XJ Cherokee Technical Forum 7 09-08-2010 05:21 PM
Need help,I'm lost Whackmaster XJ Cherokee Technical Forum 6 07-17-2010 02:11 AM
lost my key NJXJ91 XJ/MJ Cherokee Non-Technical Forum 8 07-10-2010 04:31 PM
I'm Lost chilidog75040 MJ Comanche Technical Forum 4 02-03-2007 11:45 PM
1999 XJ overheating im lost mekrew XJ Cherokee Technical Forum 16 03-18-2006 07:44 PM
