HELP! Age old overheating-I'm lost - Page 3 - JeepForum.com
post #31 of 49 Old 10-04-2012, 05:09 PM
djb383
Something's wacked, according to the chart above, 121 ohms would be give or take 300F?
djb383 is offline
post #32 of 49 Old 10-04-2012, 05:13 PM Thread Starter
BlackPearl
Oh no, that was the reading from the coolant temp sensor at the back of the engine. So it should have been around 93ohms but it was not there I didn't check the temp sending unit at the t-stat yet
BlackPearl is offline
post #33 of 49 Old 10-04-2012, 08:04 PM
djb383
Both 121 and 93 ohms r off the chart.......300-400F.
djb383 is offline
post #34 of 49 Old 10-04-2012, 08:27 PM
Reptile
1991 XJ Cherokee
He's referring to the 1st chart for the sending unit. The coolant temp sensor and sending unit have different resistance tables.
With 121 ohm, your gauge should have given you about 210F, which is normal engine temperature. You could double check using a 100 ohm resistor (Radioshack), the gauge should point to that kind of temp... doesn't look like it does. Out of curiosity, where did you get your sending unit? You have a brand/part#?
Don't rely too heavily on the reading from the coolant temp sensor. Remember it's located after the stat. If your stat is clogged and obstructs the flow, the sensor won't get nearly as hot as the engine. This threw me off when I was doing my testing... I believe your sensor is bad anyway. The coolant temp sensor controls the e-fan, which is set to kick in at 217F. And my guess is you must have had a good reason to bypass the e-fan.
Reptile is offline
post #35 of 49 Old 10-05-2012, 08:22 AM
djb383
Well duh, my bad, there r 2 charts.
djb383 is offline
post #36 of 49 Old 10-05-2012, 10:39 AM Thread Starter
BlackPearl
Yes I used the first chart, and with my sensor reading 121ohms which SHOULD be about 210 degrees, that makes me feel hopeful that my engine isn't going to explode. And at 121ohms that had my temp gauge at the 3/4 mark. So I think we are coming to the conclusion my gauge or sending unit is bad. Just to be sure I was doing it properly I'll take some photos today to show you where I was probing the sending unit.
Next order of business, I got the replacement sending unit from a Kragen/O'Reilly. But I just recently discovered there is a Jeep/AMC salvage yard not far from me and I'm sure I could find a used one there from my exact make and model.
And yes I believe my sensor is bad anyways. I just bought a replacement stock e-fan, plugged it in, my gauge got to almost redline and the fan didn't kick on...and I know the fan works because I hooked it up to power before plugging it in.
post #37 of 49 Old 10-05-2012, 12:31 PM
Reptile
1991 XJ Cherokee
It doesn't hurt to test both of them in boiling water and compare to the chart. That way you're testing against a known temperature which happens to be pretty close to normal engine temperature.
O'Reilly could not find the sensor and it looked like their website had universal units which I didn't want to gamble with. At the store they looked at me funny... They had no clue what I was talking about.
When you disconnect the sensor and engine is warm does the gauge move at all? Im thinking you could have a wiring issue between the gauge and the sensor. It occurs to me that the default gauge reading is close to where you describe it, as if it wasn't receiving an input signal... Just a thought.
Reptile is offline
post #38 of 49 Old 10-06-2012, 09:13 AM Thread Starter
BlackPearl
When the engine is warm and I disconnect the sensor at the back of the engine the gauge in on the dash drops to zero...
But I'm going to be doing work on the Jeep all this morning. Hopefully things come together
post #39 of 49 Old 10-06-2012, 12:29 PM Thread Starter
BlackPearl
So I just pulled my water pump and I'm pretty sure I found my problem, I don't see an "R" tramped on it...which means the water was being pumped the wrong way
post #40 of 49 Old 10-06-2012, 12:43 PM
Reptile
1991 XJ Cherokee
I don't know how you can visually tell whether it's a reverse rotation pump... I suppose the direction of the impeller? But it does look like the one I replaced not so long ago...
Reptile is offline
post #41 of 49 Old 10-06-2012, 01:28 PM Thread Starter
BlackPearl
From what I've been reading it should have an "R" stamped on the blades
post #42 of 49 Old 10-06-2012, 02:08 PM
Millermagic
Did you get the 3 e-fan kit from ebay? Buddy of mine has one on his cherokee and it constantly overheats.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #43 of 49 Old 10-06-2012, 03:19 PM Thread Starter
BlackPearl
So after everything that has gone on, I just found a crack on the block. It's on the coolant side, outside of the engine. This picture is the opening for the water pump, and it extends to outside of the engine. Other than causing leaks would this be the contributing factor to overheating?
post #44 of 49 Old 10-06-2012, 03:20 PM Thread Starter
BlackPearl
And yes those were the fans I originally bought but have since see back to the original stock fan
post #45 of 49 Old 10-06-2012, 04:43 PM
Pats94
How far does the crack go? Is it leaking?
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
cooling , issues , overheating
Lost pwmach1 XJ Cherokee Technical Forum 7 09-08-2010 04:21 PM
Need help,I'm lost Whackmaster XJ Cherokee Technical Forum 6 07-17-2010 01:11 AM
lost my key NJXJ91 XJ/MJ Cherokee Non-Technical Forum 8 07-10-2010 03:31 PM
I'm Lost chilidog75040 MJ Comanche Technical Forum 4 02-03-2007 10:45 PM
1999 XJ overheating im lost mekrew XJ Cherokee Technical Forum 16 03-18-2006 06:44 PM
