HELP!!!! 91 jeep cherokee 4.0 Extremely Rough Idle - JeepForum.com
post #1 of 2 Old 04-16-2005, 09:04 PM Thread Starter
dspivey
I changed the alternator in my jeep and ever since then it has run extremely rough. Starts fine, idles rough, runs rough and getting worse. It doesn't seen to be shifting properly. Around 40-45 mph it starts to bog down and run really rough, I have to floor it to get it to shift down to be able to get it back up to speed and shift gears.
91 Jeep Cherokee Laredo, 6 cyl, 4.0
dspivey is offline
post #2 of 2 Old 04-16-2005, 09:09 PM
CowboyPA
Go back over all of your alternator work and the area around it.. Maybe you left something unplugged or a ground wire that you didn't reattach.. Maybe you bumped something and it came loose? Maybe you somehow pinched some wires?
Check the coil wire, check all of your spark plug wires.. Make sure all of your connections are tight.. I pinched a wire once installing a transmission, ran great untill you turned on the headlights. Youd be surprised what a simple little ooops can cause
99 XJ sport, Black, 4 door, 4 litre, 4wd
Black Jeep club member # 99
ASE Certified and professional Auto technician 12+ years
Every rose has it's Thorn, every XJ has it's leak, and every cowboy sings a sad sad song
CowboyPA is offline
Jeep Cherokee has rough/low idle and is stalling hotmomma XJ Cherokee Technical Forum 43 01-11-2016 11:05 AM
96 4.0, Starts fine, EXTREMELY rough idle, dies very soon after start Jameslol XJ Cherokee Technical Forum 8 01-20-2010 08:39 AM
Rough Idle on '99 Cherokee--TPS XJER XJ Cherokee Technical Forum 7 10-02-2007 10:19 PM
extremely low idle E6V6I6L XJ Cherokee Technical Forum 11 02-17-2006 02:41 PM
1992 cherokee rough idle - fixed bdhaley XJ Cherokee Technical Forum 0 11-10-2005 04:13 PM
