help with 89 overflow tank leak - JeepForum.com
post #1 of 5 Old 04-27-2005, 10:28 AM Thread Starter
eas020223
I have a 89 cherokee with the plastic overflow tank. About had to buy a new one becouse the original had a small leak around the hose neck so i bought a new one at car quest. Well the new tank leaks from the side and the cap area. So i bought a new cap and it still leake?? any ideas on what it can be?? The jeep runs fine and cool
eas020223 is offline
post #2 of 5 Old 04-27-2005, 10:36 AM
XJ-NoDough
XJ-NoDough's Avatar
It's a poor design, to start with IMO. I also have an '89 , but I think this issue is one most of has been victim to one way or another. Mine leaks from the cap on the "pressure tank". When I bought it from my buddy, he mentioned that he had replaced the tank several times, from it splitting wide open. You might want to have a look at www.madxj.com, look under "technical" then click "engine" and "budget cooling upgrade (Closed to Open)". I'm seriously thinking about performing this on mine.
Have you burped the cooling system? Ie. gotten all the air out of it, because the air will expand alot farther than the coolant at raised temps. thus forcing coolant out where ever it can find a path.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #3 of 5 Old 04-27-2005, 10:51 AM
cmotsvt
^^^What he said^^^
Somebody should come up with an aftermarket metal tank reservoir.
cmotsvt is offline
post #4 of 5 Old 04-27-2005, 11:08 AM
90lerado
90lerado's Avatar
they have metal tanks i forget who sells trhem tho. what i did when mine leaked at the hose bung is i cut it smooth and added a fitting to it and it worked. as far as the cracking, jb weld is your friend lol.
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts"
- General George Patton Jr, "War as I knew it" 1947
Wife's/my vehicle: 06 Pontiac vibe awd
Hopefully a jeep sometime in the future
90lerado is offline
post #5 of 5 Old 04-27-2005, 12:16 PM
Koenig
Koenig's Avatar
My 88 XJ would also leak out of the plastic overflow. I found that if I didn't tighten the cap AS hard that it would leak a lot less or not at all. I think by over-tightening, the cap lost it's ability to release built up pressure. Just a thought, but give it a try it before replacing the bottle!
~147,000km, 4.0l, AW4, K&N custom cone intake,
Dark Cordovan Pearl Metallic in color, 4 Dr. w/ chrome trim.
Koenig is offline
1987 Cherokee Overflow tank Skaf XJ Cherokee Technical Forum 16 05-12-2013 06:35 PM
Coolant pouring out of my overflow tank jwiowa XJ Cherokee Technical Forum 7 12-19-2009 11:27 AM
Overflow tank boiling over. MSH5337 XJ Cherokee Technical Forum 12 01-08-2009 06:28 PM
overflow bottle leak? xlr84fun XJ Cherokee Technical Forum 0 06-14-2008 10:58 AM
how to fix leaking overflow tank? eas020223 XJ Cherokee Technical Forum 4 02-06-2005 02:36 PM
