HELP! 87 2dr XJ window in 88 Comanche? - JeepForum.com
post #1 of 3 Old 01-14-2011, 11:47 AM Thread Starter
jeblades
Someone decided to liberate my radio last week and broke my driver-side (roll-down) window in the process.
Question: Can I use an 87 2 door XJ driver-side window in my 88 Comanche? (both are manual windows)
jeblades is offline
post #2 of 3 Old 01-14-2011, 01:41 PM
LobstahJeep
I am not sure if they are the same, if it turns out they are different, let me know. There are 2 Commanche's in the yard here, sitting right next to each other. I can pull a window for you and send it down.
1981 CJ7
2001 XJ
ΜΟΛΩΝ ΛΑΒΕ
LobstahJeep is offline
post #3 of 3 Old 01-14-2011, 01:54 PM
camjeep3
1988 MJ Comanche
a two door window will be longer... wont fit. either get a comanche window(harder to find) or a cherokee window from a fourdoor. those fit
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline
comanche , glass , replace , window , xj
Y2K XJ - Power Window Noise When Window Reaches Top or Bottom Smittyman XJ Cherokee Technical Forum 12 03-04-2014 11:29 AM
Power window to manual window conversion? MrNate XJ Cherokee Technical Forum 5 12-29-2010 01:04 PM
99 2 door power window regulator window not lining up ??? aircruiser XJ Cherokee Technical Forum 11 05-28-2010 10:00 PM
Any info on a Power window to Manual Window Swap Fiend101 XJ Cherokee Technical Forum 5 03-26-2009 05:10 PM
Power window (window lock malfunction) question RedLeaf XJ Cherokee Technical Forum 12 07-09-2004 03:20 PM
