hella 500s on stock fog harness? - JeepForum.com
post #1 of 15 Old 05-10-2010, 01:10 PM Thread Starter
cademan04
1997 XJ Cherokee
i want to put a couple of hella 500s on my bumper and run them off the stock fog light harness and switch.
my thoughts are to cut the current plugs and put a new 2wire connector on them to keep the plug and play setup.
can the harness and relays and wiring handle the 55w hellas?
cademan04 is offline
post #2 of 15 Old 05-10-2010, 01:29 PM
cornbrizzle
1992 XJ Cherokee
Yes it can , I have the same lights wired to the exsisting wiring harness, I wouldn't go any bigger wattage wise though.
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 15 Old 05-10-2010, 02:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use the stock wire harness to activate a relay or relays. Use the relay to provide battery voltage to the fog lamps.
Cherokee wire harnesses were barely able to provide enough power and avoid switch meltdown when new.
CJ7-Tim is offline
post #4 of 15 Old 05-10-2010, 02:22 PM Thread Starter
cademan04
1997 XJ Cherokee
cj7, i like that thought. i just want to be able to use the stock switch. i have 4 driving lights on my roof rack, should i put 2 more on the bumper or get the hella fog housings?
post #5 of 15 Old 05-10-2010, 02:22 PM
robsjeepxj
I've got the Hella 500's on my XJ and my GF's TJ both hooked up to the factory wiring and it has worked fine for a number of years now. The Hella 500's are 55 watts just like the factory fogs are so your good there but as was already said if you change out the bulbs to something higher it will burn out the switch and possible the wiring too.
robsjeepxj is offline
post #6 of 15 Old 05-10-2010, 02:39 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
im running them on mine with no problems. i even put silverstar H3 replacement bulbs. huge improvement
1990JEEPXJ is offline
post #7 of 15 Old 05-10-2010, 02:46 PM Thread Starter
cademan04
1997 XJ Cherokee
you are running the hellas with h3 bulbs? what wattage are they? im still a bit of a novice with lighting and electronics.
post #8 of 15 Old 05-10-2010, 03:13 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
yeah. H3 is just the type of bulb. and silverstar is a brand that puts out a brighter, more white light than the stock hellas. same watts and they just plug in. got them at autozone
post #9 of 15 Old 05-10-2010, 03:18 PM Thread Starter
cademan04
1997 XJ Cherokee
sweet i may upgrade my roof arck lights with them
post #10 of 15 Old 05-10-2010, 03:21 PM
irishgobrah
1995 XJ Cherokee
I am using the stock switch for a pair of 100 watt kc's. I used the harness that came with the kit but kept the stock switch for the clean look.
-Casey
93 XJ :Rusty's 3" w/ 31x11.5 swampers-hooked my brother up
96 XJ :Rusty's intake/exhaust kit-hooked my dad up
00 WJ :clear lenses from an 04-wife's DD
95 XJ :2dr slowly coming along!
irishgobrah is offline
post #11 of 15 Old 05-10-2010, 05:43 PM Thread Starter
cademan04
1997 XJ Cherokee
what r yalls thoughts on putting the fog beams vs driving lights?
post #12 of 15 Old 05-10-2010, 07:14 PM
oderalxjlaredo
I put 55w driving lights in the factory fog location. Supposedly it's illegal to use them on the road here but I sometimes use them on dark, empty stretches of highway I'm going to rewire the setup so that I can turn them on in conjunction with the high-beams if desired. The stock circuit turns off the fog lamps if you click the high beams on.
by the thing that spins when you drive underneath
oderalxjlaredo is offline
post #13 of 15 Old 05-10-2010, 07:26 PM Thread Starter
cademan04
1997 XJ Cherokee
I guess what I'm asking is, will fog lights give me a fuller brightness in my setup. I have 4 driving lights on the roofrack. should I add 2 more pencil beam driving lights or put 2 fog pattern lights to fill in some of the closer range areas the pencil beams don't direct at?
I will definitely be bypassing the stock harness pretty soon so I can operate the lights at my desire.
post #14 of 15 Old 05-10-2010, 07:28 PM
oderalxjlaredo
True fog lights are angled downward to prevent blinding yourself in rain or fog conditions, often have a lesser wattage (35 vs 55 w), and are usually yellow in color. So yes, I think driving lights would be noticeably brighter.
post #15 of 15 Old 05-11-2010, 08:08 AM Thread Starter
cademan04
1997 XJ Cherokee
that makes sense. however, i just looked at the hella website. they do have the 500s in a driving pattern and a fog pattern, both at 55w.
Hella 500s on Nates4x4 Slimline Front Bumper? Flojo8000 XJ Cherokee Technical Forum 1 09-18-2009 05:01 PM
Hella 500s installed--tech question-- FISTFULL XJ Cherokee Technical Forum 8 07-30-2007 06:17 PM
Hella 500s johnconners XJ Cherokee Technical Forum 5 08-24-2006 08:37 PM
Hella 500s on the Surco......... Rasta_Coty XJ Cherokee Technical Forum 2 04-17-2006 03:07 PM
Hella 500s on stock bumper pretzelperson XJ Cherokee Technical Forum 3 02-18-2006 11:09 AM
