Hella 500 lights wiring - JeepForum.com
post #1 of 21 Old 02-29-2008, 05:08 AM Thread Starter
asquared829
I recently bought a 2000 jeep cherokee from a private seller. the truck is raised with offroad tires and whatnot. the guy i bought it from mounted hella lights on the front bumper, and said he wired them, just not all the way. there are two wires running from the lights to under my front seat, and he gave me a switch. he said all i had to do was connect the wires and switch and the lights would work, and i did that but nothing happened. any suggestions on something i could check/change to make the lights work?
asquared829 is offline
post #2 of 21 Old 02-29-2008, 05:54 AM
darkhanger18
If i were you, i wouldnt trust the PO's wiring. The lights should be wired with a relay, to give them maximum brightness. http://www.suvlights.com/images/aux_wiring_diagrams.jpg
Use something like that to help get you started.
1999 Cherokee stock suspension(for now) 235/75/15 kuhmo MT's 7" touch-screen w/nav, pheonix gold 4 ch, alpine mono, RF punch stage 2 10" subs, mb quart speakers, 2 150watt lights on the roof, fogs and driving lights on the bumper, LED lighting inside
darkhanger18 is offline
post #3 of 21 Old 02-29-2008, 06:34 AM
crosschecker
1995 XJ Cherokee
As was already posted, for safety reasons and common practice, use a relay and inline fuse in your wiring harness along with at least 16ga. wiring for legal wattage bulbs. You may also want to look into tapping into your high beam circuit if you only want the light active with your high beams.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #4 of 21 Old 02-29-2008, 06:39 AM
murrayman23
1987 XJ Cherokee
there should be 3 wires going into your driver side compartment. One from the battery, one ground, and one from the lights. is there one from the battery? if not look for a ground? he must have a wire coming from lights.
"Rusty" 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.Half Herculined Half Navy blue
murrayman23 is offline
post #5 of 21 Old 02-29-2008, 08:59 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Hella's website isn't loading right now, but they have wiring instructions.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #6 of 21 Old 02-29-2008, 01:12 PM
FransWhiteXJ
Here it is (4.5 MB!) http://www.hella.com/produktion/Hell...structions.pdf
Fran
FransWhiteXJ is offline
post #7 of 21 Old 02-29-2008, 03:15 PM
tntempest
Going in another direction, did it have the factory fog lights, if so you can just use those wires. It uses the same 55 watt bulbs as the factory fogs.
2004 Wrangler Rubicon
tntempest is offline
post #8 of 21 Old 02-29-2008, 06:34 PM
MoochsXJ
2007 WK
If you take your time and follow the hella instructions, and even do a mock up before hand it will go pretty easy. My first time with wire was when I recently put the 500's on my rubi and it came out great. It took some time but I had to be patient and I mocked everything up first then connected the battery and grounds to test if the lights worked, then reassembled the whole thing except on my truck.
'03 Rubicon - DD
Misc. Jeep stuff for sale/free
MoochsXJ is offline
post #9 of 21 Old 02-29-2008, 07:17 PM
FlexdXJ
1997 XJ Cherokee
do you have to hook the wire up to the high beams? I kinda want to be able to use my lights on high and low if it is ever needed. If it is required which color wire is for the high beams?
97 XJ 4.0 AW4 NP231: BB, 31's CB, Surco Rack, , Autopals, Scangauge II, JCR tail light housings, basically Looks like JCR puked on it and some sweet hood pins! :D
FlexdXJ is offline
post #10 of 21 Old 03-01-2008, 07:49 AM
FlexdXJ
1997 XJ Cherokee
anything guys ? i need to know before i get everything mounted
FlexdXJ is offline
post #11 of 21 Old 03-01-2008, 10:35 AM
mbood82
mbood82's Avatar
the Hellas should be wired independently of any factory wiring. Supply power to the relay from the battery, then from the relay to the lights. ground the lights. supply power to the switch and from the switch to the signal terminal on the relay, ground relay. done.
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline
post #12 of 21 Old 03-01-2008, 12:36 PM Thread Starter
asquared829
thanks for all the help! the lights are up and running. now im looking for a set of four lights to mount on my roof. anyone know where i can find a good set?
post #13 of 21 Old 03-01-2008, 12:43 PM
Matt Gertsch
www.lp.org
I tapped the high beam relay for the trigger on the driving light relay on both rigs. That's the 'proper' way to do it. Your driving lights should not come on with the low beams as it violates DOT specs, IIRC. If you want to be able to switch them off and on, then the switch goes on the ground wire for the relay.
If you absolutely need them to come off and on independently of the headlights, I'd recommend running the trigger off of a switched +12v source and putting the switch on the relay ground. Keep in mind though that it is illegal to run auxiliary lights without headlights in most states and it is discourteous and illegal to run driving lights with your low beams when there is oncoming traffic.
Fog lights should be wired to come on with low beams, driving lights should be wired to come on with high beams.
post #14 of 21 Old 03-01-2008, 12:45 PM
FransWhiteXJ
Try these guys. They're located in the same city as Hella HQ.
http://ptcfactoryoutlet.com/products...furbished.html
Fran
post #15 of 21 Old 03-01-2008, 12:54 PM
FlexdXJ
1997 XJ Cherokee
I dont want to run them with the high beams on i want them to run with the low beams on so i can have them as my long range lighting and my low beams for the close range. I don't plan on using them on the street unless absolutely necessary. I guess i will hook them up per the instructions and see what i get then thanks for the input
FlexdXJ is offline
Best wiring for hella fog lights ytownxj XJ Cherokee Technical Forum 1 01-04-2010 12:10 PM
Hella 500 switch wiring. willcherokeexj XJ/MJ Cherokee Non-Technical Forum 12 09-07-2009 05:46 AM
Using Hella Lights For Low Beam Driving Lights allibaster XJ Cherokee Technical Forum 7 05-24-2009 08:22 PM
Hella 500 wiring: Wisbar XJ Cherokee Technical Forum 31 08-09-2005 08:41 PM
Wiring Hella 500's crookedletterd XJ Cherokee Technical Forum 6 07-11-2003 11:44 PM
