heim joint on shocks - JeepForum.com
post #1 of 6 Old 05-30-2012, 06:08 PM Thread Starter
JHW12084
1990 XJ Cherokee
i am curious if anyone has or ever heard of putting a female heim joint on the end of their shocks instead of purchasing new ones? purchasing new ones arent a problem, but i'd rather not, since my shocks are less then 8 months old.
JHW12084 is offline
post #2 of 6 Old 05-30-2012, 06:58 PM
wgirvine
1992 XJ Cherokee
Instead of purchasing new ones... what? New Heim joints? New shocks? If your shocks are worn out, new Heim joints on the ends won't help.
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 6 Old 05-30-2012, 07:05 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
No need, rubber or poly bushings are sufficient ( and quieter ).
CJ7-Tim is offline
post #4 of 6 Old 05-30-2012, 07:13 PM
wgirvine
1992 XJ Cherokee
Tim, I agree completely. I was just trying to figure out what he was talkin' about...
wgirvine is offline
post #5 of 6 Old 05-30-2012, 07:56 PM Thread Starter
JHW12084
1990 XJ Cherokee
no no no..... you guys arent getting what i meant. i have a 6" lift on my xj. i have skyjacker nitro shocks for the 6" lift. i also have an iro long arm kit on my xj. the 6" shocks wont let the suspension cycle and droop when flexing and limits downward axle travel. i have the synergy shock stem conversion on order to accept a loop style shock. if i add a heim joint with the stem conversion, i can add around 4" of added shock travel and will only have around 20-30 bucks in the heims, instead of 30-45 per shock. see what i'm gettin at?
JHW12084 is offline
post #6 of 6 Old 05-30-2012, 08:01 PM Thread Starter
JHW12084
1990 XJ Cherokee
no bushings are wore out, im just trying to improvise with what i have......
JHW12084 is offline
Trackbar heim joint failed twice cherokeekid58 XJ Cherokee Technical Forum 6 06-13-2011 11:21 AM
Heim joints Grinola XJ Cherokee Technical Forum 5 03-10-2009 09:22 PM
Heim Joint Noise XJRookie XJ Cherokee Technical Forum 13 05-28-2008 07:41 PM
Heim joints tweekedknee XJ Cherokee Technical Forum 1 07-01-2006 06:52 PM
HEIM Joints Mikey B XJ Cherokee Technical Forum 6 07-09-2004 01:15 PM
