Heater is warm, but not HOT - JeepForum.com
post #1 of 13 Old 12-02-2004, 04:41 PM Thread Starter
WRFD17
WRFD17's Avatar
Changed the thermostat today, flushed the system last winter. But, it's still not as hot as it used to be. Any ideas ???
Blue '04 TJ Columbia Edition
N R A JEEP Club # 1
Blue Jeep Club Member #57
Firefighting Jeep Club #4
M.W.J.T.
WRFD17 is offline
post #2 of 13 Old 12-02-2004, 04:58 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
What is your operating temp at on the gauge? Did you replace the Tstat with a 195 unit?
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 13 Old 12-02-2004, 05:29 PM
Rogo98Sport
You might have air in your cooling system.
Take your radiator cap off and run the engine. Air bubbles should come out. Don't be afraid to rev the engine a little.
Rogo98Sport is offline
post #4 of 13 Old 12-02-2004, 06:44 PM
cyberbackpacker
cyberbackpacker's Avatar
Flush your heater core independently from the radiator. The majority of the time, this solves the problem. Cheap, and effective.
-Kevin
cyberbackpacker
cyberbackpacker is offline
post #5 of 13 Old 12-02-2004, 07:07 PM Thread Starter
WRFD17
WRFD17's Avatar
Yes the new and old stats are 195's. The gauge goes up to and stays @ 210 as it always has. I did burp the system after refilling what I lost when changing the stat.
N R A JEEP Club # 1
M.W.J.T.
WRFD17 is offline
post #6 of 13 Old 12-03-2004, 12:55 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I forgot that one, cyberbackpacker might have nailed it though. Clean out the Heater core as well and see if you get more heat.
If you are getting up to 210 that would be the thing to look at, that or nake sure the heater control valve vac line is on there good and tight and not leaking. Also make sure it is opening and closing fully.
93 Sport
Specs in Profile.
balloo93 is offline
post #7 of 13 Old 12-03-2004, 06:20 AM
dm7297
dm7297's Avatar
1995 XJ Cherokee
im having the same problem where the heat gets warm but not hot, i suspect its the heater core, since when i flushed my rad. was really nasty, does anyone have a link or a write up on how to flush the heater core by its self?
1995 Jeep Cherokee Country, 6.5" Long arm lift, front & rear arbs, 35" superswamper trxus m/t's 8.8, ridigco winch bumper, roof rack,
Check it out.
dm7297 is offline
post #8 of 13 Old 12-03-2004, 07:11 AM
k6zwc
1994 XJ Cherokee
Yeah my heater is the same way, I'd be very interested to see this. When I dig in to this project I'll try to take time out to take some pics.
K6ZWC with "Silver" 94 XJ SE 4.0L/AW4/NP231
k6zwc is offline
post #9 of 13 Old 12-03-2004, 02:29 PM
cyberbackpacker
Here is a link that describes what you need to do to just flush the core. It is nice and simple.
http://www.olypen.com/craigh/heater.htm
-Kevin
cyberbackpacker
post #10 of 13 Old 12-03-2004, 04:46 PM
rmousir
it is your heater core. most likely starting to clogg. If your jeep is as old as mine just spend the $15 for a new one and be done with it.
Good luck.
Richard.
Richard
1991 Jeep Cheorkee 'Cancer' *retired Oct'06
1994 Jeep Cherokee Country
4.0 H.O. Auto 2 wd
rmousir is offline
post #11 of 13 Old 12-23-2004, 08:37 AM Thread Starter
WRFD17
WRFD17's Avatar
OK, thanks for all the help but, still no luck, replaced the thermostat, replaced the vac line where it was compromised, the fluid is good to -25, I just flushed the heater core, let it run outside for 20 min., that didn't work. The air coming out of the defroster vents for the side windows is very cold, the front floor vents are kind of warm, the vents for rear on back of the center console are warmer than the rest. Where is the heater control valve and how do I check it ?? Pics would help. It is 10 F out today and the wife keeps taking my TJ because it's warmer, even with the soft top.
N R A JEEP Club # 1
M.W.J.T.
WRFD17 is offline
post #12 of 13 Old 12-23-2004, 08:42 AM
Sir Fuzzitoes
Sir Fuzzitoes's Avatar
sorry, no help here, but that line is an instant classic!
2000 XJ Sport 4.0L #235
[/SIZE][/FONT]. . .Off Road Armor that's "Tough as Scales"
Sir Fuzzitoes is offline
post #13 of 13 Old 12-23-2004, 08:45 AM Thread Starter
WRFD17
WRFD17's Avatar
Thanks.............both upper & lower hoses coming from the heater core are hot.
N R A JEEP Club # 1
M.W.J.T.
WRFD17 is offline
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 09:53 PM
Heater blowing warm air while idling jeffb1113 XJ Cherokee Technical Forum 2 04-12-2009 09:19 AM
Cherokee heater only luke warm hearld5000 XJ Cherokee Technical Forum 7 01-09-2009 06:56 PM
Heater blows cold air while driving and just warm air when sitting. 4X4XJJeep XJ Cherokee Technical Forum 11 12-22-2008 11:06 AM
Heater blows air, sometimes warm, but not hot.. OtsiderCherokee XJ Cherokee Technical Forum 7 11-25-2008 10:59 AM
