Heater switch half broken, Headlight switch completely broken. Halp!
#1 | |
Well we will start with the headlight switch, its definitely messed up, my question is, the junkyard here is severely lacking in older xjs, so is it possible to use a grand cherokee or another vehicle pull switch? if not would napa or autozone carry it?
Now to the heater switch, my heat works in all settings and blows correctly, but it only works on the highest setting, the other settings will not work at all, so its high or nothing. Would this just be the heat switch or could it be a vacuum hose leak? Thanks in advance, appreciate it.
Black 1996 Jeep Cherokee Sport, 4.0, 4WD, NP231. 31 inch Yokohama Geolanders. 3" Rough Country AAL Kit. ZJ tierod. C4x4 Front tow hooks. Nates 4x4 rear bumper w/receiver and shackles Iron rock offroad double shear adj trackbar |
#2 |
Go Jeepin
Try the links below for both parts. The blower fan needs a new blower motor resistor. They are simple to replace, use the SEARCH for more info - http://www.jeepforum.com/forum/search.php
http://www.chryslerjeepdodgeparts.com/oem_parts.html http://www.teamcherokee.com/ http://www.jeepsareus.com/Merchant2/merchant.mvc?
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
