Heater stuck on ? - JeepForum.com
post #1 of 6 Old 05-16-2006, 06:32 PM Thread Starter
Igofaster
Heater stuck on ?
I can feel heat when I am driving the jeep. The heater is in the off position, and its not blowing heat, Just seeping out. What could be wrong?
91 jeep cherokee 4.0 2wd - soon to go to the paint shop!
Igofaster is offline
post #2 of 6 Old 05-16-2006, 06:46 PM
wizardPC
every car I've ever owned has done this. Move the temperature selector all the way to the cold side.
wizardPC is offline
post #3 of 6 Old 05-16-2006, 07:56 PM
markmca82
Mine does the same thing (It gets close to 85-90° inside when it is 60-65° outside). Not sure what is causing it but I'm am going to look into it this weekend or next. If I figure it out I will let you know.
Mark
Black 1989 Limited 4.0L XJ
Rough Country 3" AAL
Pro Comp Xterain 31X10.50X15
Pro Comp 97 Series Rims
"Martinez" Edition
markmca82 is offline
post #4 of 6 Old 05-16-2006, 08:12 PM
Tree Frog
Tree Frog's Avatar
Your heater control valve is stuck open. Follow your heater hose to the block and you'll find it.
Tree Frog is offline
post #5 of 6 Old 05-17-2006, 11:22 AM
PoPilot
x2.
Check to make sure the vacumm lines are still attached to it.
PoPilot is offline
post #6 of 6 Old 05-17-2006, 01:51 PM Thread Starter
Igofaster
So I should replace the heater control valve?
AC/Heater vent....stuck on blowing only from the defrost vent xjinga XJ Cherokee Technical Forum 7 07-10-2015 01:03 PM
Heater/a/c fan switch stuck lonestar_yj XJ Cherokee Technical Forum 0 12-15-2009 08:28 PM
heater control stuck? IDAHOPIONEER XJ Cherokee Technical Forum 0 03-19-2009 07:37 AM
pop? can stuck in my Heater...HELP jeepjack1995 XJ Cherokee Technical Forum 3 10-20-2008 03:39 PM
heater stuck on Igofaster XJ Cherokee Technical Forum 2 06-12-2006 08:32 PM
