heater fan problem - JeepForum.com
post #1 of 5 Old 10-18-2006, 12:35 PM Thread Starter
skunkmere
heater fan problem
i got a problem with my heater/ac fan, it will only blow on high its off on low or mid level, and it makes a horrible sound when i start it or while it's on. do you guys think i need to replace it or oil it. and if so how do i pull it out.
thanks
skunkmere
1996 XJ country I6 HO ho ho
95k stock everything exept the mobile 1 synth oil
green and tan color.
thinking about doing it all, but then again **** it i can wait until im rich.
skunkmere is offline
post #2 of 5 Old 10-18-2006, 01:00 PM
XJING
Heres the fix for it only being on high, you burnt out the resistor. The write up shows one from Radio Shack, but the whole peice is not $$ at the dealer either. As for its making noise. It could be filled will leaf and bark if you haven't used it in some time. If thats not the case its probably on its way out. Anyways heres the write up. Good Luck
http://www.geocities.com/chmwatson/F...elink_fix.html
Originally Posted by FleXJ the Kid
Yes, probably, I dont know. I could but sometimes it was difficult. Just get under there and try.
XJING is offline
post #3 of 5 Old 10-19-2006, 09:20 AM Thread Starter
skunkmere
thanks for the post xjing
post #4 of 5 Old 10-20-2006, 06:18 AM Thread Starter
skunkmere
it worked i now have low and mid blower speed thanks again xjing!
post #5 of 5 Old 10-20-2006, 06:32 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
FWIW, the stealership told me, and it makes sense, that if the blower motor is weak (possibly from running on high for a long period of time) that the thermal fuse will continue to blow due to overheating in the air duct (which is what it is meant to protect against) and the blower motor may need to be replaced.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
Heater Problem jeepnick XJ Cherokee Technical Forum 1 10-30-2009 12:25 AM
heater problem 99XJRider XJ Cherokee Technical Forum 1 12-12-2007 09:16 PM
ac/heater problem joe86 XJ Cherokee Technical Forum 4 11-10-2007 10:44 PM
heater problem cherokeejoe XJ Cherokee Technical Forum 2 12-16-2005 04:29 PM
Need Help with Heater Problem projectX XJ Cherokee Technical Forum 1 01-25-2004 07:11 PM
