Heater Core Replaced, Blower Motor Replaced, still see white smoke - JeepForum.com
post #1 of 11 Old 12-16-2011, 01:24 PM Thread Starter
ONEWAYXJ
Hello Jeep Forum,
Almost a year ago I noticed coolant leaking onto the floorboards of my XJ. Thanks to this forum we were able to remove the dash, replace the old and faulty heater core, and put the dash back in place. At the time when we replaced the heater core everything worked. A few months after we replaced the heater core, I turned on the defroster and white smoke came through the vents (didn't smell like coolant, it smelled like old ciagarette ashes). There was also no air coming through the vents. My logic was that the blower motor had burned up. The Jeep is a 97 Cherokee Sport 4.0. We replaced the blower motor today and the same white smoke is coming through the vents when I turn on the heat and I still do not have air coming through the vents. Can someone please let me know if there is something else I need to replace or do?
Thank you.
-onewayXJ
ONEWAYXJ is offline
post #2 of 11 Old 12-16-2011, 02:12 PM
AZ Jeff
2014 JK Wrangler
You say the following: "We replaced the blower motor today and the same white smoke is coming through the vents when I turn on the heat and I still do not have air coming through the vents."
Can you explain more clearly what you mean?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 11 Old 12-17-2011, 09:40 AM
rjbruzan
The blower switch burning the wires at the back of it. Pull the switch out of the dash board and visually check the wires for damage.
rjbruzan is offline
post #4 of 11 Old 12-17-2011, 03:06 PM
residentg
I read something about this on this forum or the Cherokee forum with photos of your symptoms. It was the result of something going bad, but I cannot recall what it was. Do a search and post the link if you find it. Thank you.
residentg is offline
post #5 of 11 Old 12-19-2011, 08:52 AM Thread Starter
ONEWAYXJ
Sure, we thought maybe the motor was burning up and needed to be replaced so we put in a new motor and started the engine to test it. When we turned power to the jeep, we should have been able to hear and feel the blower motor turning on, but we didnt. We turned the engine over, and the motor of course still didnt kick on, but after we ran the jeep for a minute or so we began to see a light smoke creeping out of the interior dash vents.
ONEWAYXJ is offline
post #6 of 11 Old 12-19-2011, 10:12 AM
teknics
I'm guessing same as guy up a few posts melted connector on blower resistor or fan speed switch. Prob burning wires
teknics is offline
post #7 of 11 Old 12-19-2011, 12:24 PM
AZ Jeff
2014 JK Wrangler
Ah...you mean you see wisps of white smoke through the vents, but no forced air from the fan through those same vents.
The issue most likely is the blower resistor pack, as others have noted, but a little work with a VOM might be in order here to check the circuit wiring.
AZ-Jeff
AZ Jeff is offline
post #8 of 11 Old 01-02-2012, 11:41 AM Thread Starter
ONEWAYXJ
Is this what you all are refering to? Thanks!
http://www.cherokeetalk.com/forum/f6...acement-11133/
ONEWAYXJ is offline
post #9 of 11 Old 01-02-2012, 05:01 PM Thread Starter
ONEWAYXJ
We replaced the stock BMR switch with an RU1046 BWD resistor from Advance Auto. The blower motor is still not cutting on and there is no air coming from the vents. So far we have already replaced the heater core, blower motor, and now the blower motor resistor. Any ideas as to what else we can check? Thanks.
ONEWAYXJ is offline
post #10 of 11 Old 01-05-2012, 03:03 PM Thread Starter
ONEWAYXJ
Update: We just checked the fan blower fuse and it is perfectly fine. Not sure what else we can check.
ONEWAYXJ is offline
post #11 of 11 Old 01-09-2012, 04:59 PM
AZ Jeff
2014 JK Wrangler
Let's slow down here. Throwing parts at this is NOT fixing the problem, obviously. Do you own a VOM? If not, buy a cheap one, it will help you solve this problem.
Then start tracing the power from the fuse on out to the blower motor.
Is there power TO the fuse? Is there power coming OUT of the fuse? Is there power at the switch? How about at the resistor pack? How about at the blower motor proper?
AZ-Jeff
AZ Jeff is offline
blower motor , heater core , no air
92 xj blower motor problem-replaced components Underoath4177 XJ Cherokee Technical Forum 1 11-15-2011 05:34 PM
replaced heater core now blower wont work?? Orchy88 XJ Cherokee Technical Forum 2 12-01-2010 02:29 PM
replaced heater core, now no wipers? RaccoonJoe XJ Cherokee Technical Forum 1 02-11-2009 08:43 AM
Bad blower motor and heater core starhawk2888 XJ Cherokee Technical Forum 6 12-31-2008 10:49 PM
Stupid heater core needs replaced ksturgio XJ Cherokee Technical Forum 18 12-03-2008 06:16 PM
