Heater Core and Evap Core at the same time? - JeepForum.com
post #1 of 7 Old 07-12-2011, 02:27 PM Thread Starter
mfinkler
OK, I have a 96 with 130k on it. Heater core is leaking. A/C system works fine so I assume no leak in the evap core but would you put a new evap core at the same time? Would hate for it to start leaking over the next year and have to do all of this again.
mfinkler is offline
post #2 of 7 Old 07-12-2011, 02:28 PM
AZ Jeff
2014 JK Wrangler
When my 2000 heater core started leaking, I took no chances----I replaced the evaporator at the same time. Why risk doing the labor twice when it's such a big PITA to do the job?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 7 Old 07-12-2011, 02:41 PM
Kevin108
Definitely at the same time! Good write up at http://www.jeepforum.com/forum/f11/m...thread-592844/
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #4 of 7 Old 07-12-2011, 02:59 PM
Timo_90xj
Timo_90xj's Avatar
Yup, do it at the same time.
That little extra investment is gonna pay you back. Chances are your evap core could be the original unit, so it's not exactly new. If you don't replace it now, I bet it'll blow up within a few days after putting everything back together
***Under construction***
Timo_90xj is offline
post #5 of 7 Old 07-12-2011, 08:35 PM
Ih8Hondas
Always do both at once. I'm working on mine right now. I was just going to replace my leaky evaporator core but once I found out how much of a PITA it is I went and got a heater core too. I don't plan on ever doing this job again myself. I'll just stick to playing with engines.
1998 Jeep XJ: 4.0, AX15
2006 Yamaha YZ250: Stock
Ih8Hondas is offline
post #6 of 7 Old 07-13-2011, 10:39 AM
mhall02
I had the reverse of the OP (evaporator was leaking, not the hater core), but had both done at the same time since it is such a pain and you are there any way. The heater core was original, but the evaporator....well I'm on number 3 (original factory unit, warranty unit after 3 years, and now this non-Mopar unit which I hope will last longer than the first two).
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #7 of 7 Old 07-13-2011, 11:07 AM
1976j10
1976 J-Series Truck
I'd go ahead and do it. Why take the dash out twice when you can fix everything on the first try?
1976j10 is offline
Evap core rpriore XJ Cherokee Technical Forum 5 05-03-2011 11:53 AM
Clarification For EVAP core swap 99Greenmachine XJ Cherokee Technical Forum 6 06-07-2010 03:26 PM
evap core leak? wyojeep92 XJ Cherokee Technical Forum 3 06-17-2009 11:33 PM
AC leak / evap core replace robin1t2002 XJ Cherokee Technical Forum 2 10-25-2007 10:38 AM
Evap Core dcuballa XJ Cherokee Technical Forum 2 08-19-2005 08:10 AM
