Heater Core Bypass? - JeepForum.com
post #1 of 5 Old 12-02-2008, 01:33 PM Thread Starter
afguy
Heater Core Bypass?
My heater core is leaking a little and I live in Hawaii, so I will never use the heat. I was thinking of bypassing it by connecting the two hoses together. Any foreseen problems with this?
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies.
afguy is offline
post #2 of 5 Old 12-02-2008, 03:21 PM
440_Magnum
I don't think it should be a problem, just make sure you bend the hoses smoothly without kinks so that water can flow. IIRC, the 2.5 / 4.0 uses the heater core as the thermostat bypass, so it needs to allow water to flow to let the engine warm up evenly and to warm the thermostat so that it will open at the right time.
440_Magnum is offline
post #3 of 5 Old 12-02-2008, 03:33 PM
conrasm
conrasm's Avatar
You'll need some type of adapter to connect them. The hoses are different sizes, 5/8 and 3/4 I think.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #4 of 5 Old 12-02-2008, 04:12 PM
ksturgio
I bought a hose T for like $1. Mine has been running Bypassed for almost a year with no problems. The only thing is it seems to run a tad warmer then it used to. I going to try to takle my heater core replacement tomorrow. I'm going to try and take pictures and post my take on it in the future.
ksturgio is offline
post #5 of 5 Old 12-03-2008, 10:25 AM Thread Starter
afguy
Tackling the heater core isn't that bad of a job its just that its not really worth the money since I never use it.
afguy is offline
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 09:53 PM
90 xj heater core bypass ? end broke dieselkiller XJ Cherokee Technical Forum 2 08-08-2009 12:58 PM
Heater core rit.05 XJ Cherokee Technical Forum 1 01-13-2009 08:15 PM
Heater bypass valve Dave41079 XJ Cherokee Technical Forum 2 02-07-2006 06:29 PM
Heater core bypass valve? Sanchez XJ Cherokee Technical Forum 2 05-16-2005 03:20 PM
