Heater control lights - JeepForum.com
post #1 of 8 Old 01-10-2006, 08:04 PM Thread Starter
dcuballa
Does the heater control/AC control light up when you turn the lights on. I thought it did and since I recently took the dash out so I dont know if I didnt hook something back up or not. So if anyone can answer this....it would help me trying to find a wire under the dash....(if it does light up what does the wire look like) and on this topic now when I turn my headlight switch over to turn on the inside lights....they wont light up.....whats the deal with that....where is that wire, I thought since it was one single switch it would be that 6 prong connector on the light switch itself.....any help would be so great!!
07-Driver Unknown
Sponsor Unknown Chevy Silverado
08-Driver Unknown
HOLY CRAP THATS A LOT OF UNKNOWNS
dcuballa is offline
post #2 of 8 Old 01-11-2006, 10:38 AM Thread Starter
dcuballa
anybody...plus 20 and a few more......
07-Driver Unknown
08-Driver Unknown
dcuballa is offline
post #3 of 8 Old 01-11-2006, 10:50 AM
01JeepXJ
01JeepXJ's Avatar
they should come on when you turn the lights on
check some fuses
2001 Steel Blue Metallic XJ
(3.5", Rock Monitor Bumper ,Gila Monster Quarter Guards , Super Skink Sliders)
33"Trxus MT's-OME Shocks-PMW Door armor-H4 IPF Headlights-Labaron Hood Vents
**SOLD **
01JeepXJ is offline
post #4 of 8 Old 01-11-2006, 10:55 AM
kencaz
Yes the heater control lights up. There is a bulb behind on the right side. A twist will remove it. try re-seating the bulb and it should work.
For the dome light, yes it is tied into the headlight switch as well as the door open switches. Does the dome work when you open the door? If not then it's probably the bulb, if so then you'll have to pull the light switch and check the wire's their. Their is a rheostat on the front of the switch for dimming the dash. if you turn it all the way you will see where it make's contact to turn the dome light on. see if it is making good contact there.
Good Luck
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #5 of 8 Old 01-11-2006, 11:06 AM
XJ-NoDough
XJ-NoDough's Avatar
For the dome light, could be a dirty pin-switch in the door jamb.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #6 of 8 Old 01-11-2006, 04:05 PM Thread Starter
dcuballa
Ok....the dome lights light up whenever the door is opened....but they dont when you turn the light switch over....so that is the connector.....whats the easiest way to get to this other than having to take the dash apart again
07-Driver Unknown
08-Driver Unknown
dcuballa is offline
post #7 of 8 Old 01-11-2006, 04:16 PM
mylt1
mylt1's Avatar
you have either a broken or cut wire. some where between the switch and the lights. see of you can find a wiring diagram for your xj it will tell you what color and a round about way it is run.
mylt1 is offline
post #8 of 8 Old 01-11-2006, 05:41 PM
kencaz
You can remove the switch from under the dash, however, it's a bear to get at and the harness is very short, (on mine at least). Check the Yellow wire into the harness, if it's connected properly then it's probably within the switch. I (myself) would not replace the headlamp switch just for the dome light.
If I were you I would just get an SPST switch, 2 feet of wire, find the connector for the door switch, connect the Yellow and Black wires to the switch. Then you have a manual overide for the driver's door switch.
KC
kencaz is offline
dash lights behind heater control panel? asjeep XJ Cherokee Technical Forum 6 08-11-2014 10:14 PM
need help with heater hose routing around heater control valve jerry4570 XJ Cherokee Technical Forum 2 10-11-2009 11:35 AM
heater control bobbyracer XJ Cherokee Technical Forum 7 09-18-2008 06:59 PM
Heater control lights Indslpwr04 XJ Cherokee Technical Forum 1 12-10-2007 11:59 PM
89 Heater Control lights OC XJ XJ Cherokee Technical Forum 3 04-10-2003 05:39 AM
