Heater blower only works on high - JeepForum.com
post #1 of 17 Old 11-20-2008, 05:50 PM Thread Starter
achipnachair
I cant figure it out. Only High works. Blows where I want it to. HELP PLEASE
achipnachair is offline
post #2 of 17 Old 11-20-2008, 05:51 PM
ItzaKaDoozie
check the switch. evidently the things are legendary for failing in jeeps.
g'luck
ItzaKaDoozie is offline
post #3 of 17 Old 11-20-2008, 05:52 PM
RckRdyXJ
RckRdyXJ's Avatar
2005 WK
Blower motor relay under dash on pass side about $40. Defrost is the fail safe mode. Its got 1 plug and 2 screws.
2005 WK Limited 4.7 V8, Custom CAI, Custom Exhaust, 08 Overland front end
2006 Jeep Liberty Sport 2.8L CRD
RckRdyXJ is offline
post #4 of 17 Old 11-20-2008, 07:51 PM Thread Starter
achipnachair
I can switch between floor, panel or defrost no problem. I just have no low or med on fan speed. Only high.
post #5 of 17 Old 11-21-2008, 08:52 AM
delstele
1997 FSJ Cherokee
There's a relay behind the glove box for the blower control bout $9 bucks at your local parts distributor
delstele is offline
post #6 of 17 Old 11-21-2008, 02:09 PM
KamekLocked
KamekLocked's Avatar
It is the blower resister because high isfrom battery power but all other speeds go through the resistor. If it works on high obviously the relay is good.
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline
post #7 of 17 Old 11-21-2008, 02:21 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
correct, the blower works just as Kameklocked described. the ability to switch from defrost to vent to floor, is controlled by vacuum.
xjfever is offline
post #8 of 17 Old 11-21-2008, 04:06 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
And, if the thermal fuse in the blower motor resistor pack has blown (which yours surely has), the blower motor itself is likely bad. Both are easy to change in a '93--the resistor pack should be under $20 at the dealer and the blowe motor should be around $30 at Advance Auto (or the like).
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #9 of 17 Old 11-21-2008, 04:13 PM Thread Starter
achipnachair
Thanks for all the help. The blower motor is fine so im going to replace the resistor and see what happens. I'll let ya know.
post #10 of 17 Old 11-22-2008, 06:41 AM
conrasm
conrasm's Avatar
You can acutally replace the thermal fuse if you like tinkering around with things. They are are about $2 at radio shack. I'll look for the write up I did when I had this problem in the past.
EDIT:
Here's a link with a few pics when I fixed mine. There are also some links to the thermal fuses that radio shack sells. They usually stock them in the store. It's a pretty easy job if you can solder. I would think you could just crimp it in also. The reisitor pack is easy to get too so you can work on it inside.
http://www.jeepforum.com/forum/f11/blower-motor-resistor-206575/
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #11 of 17 Old 11-22-2008, 07:50 AM
DLYoung1
1993 XJ Cherokee
Total agreement on the "blolwer motor resistor block" (the exact name to ask for), because I just replaced it about three days ago on my '93. Just under $17 at the local dealership. Just drop the little plastic cover located down at your right foot (if you are seated in the passenger seat), and you'll see the plug attached to the resistor block in the side of the blower housing. Five minutes and you'll have all four speeds back.
DLYoung1 in Texas
'93 Stock XJ, 4.0 2wd, AW4
DLYoung1 is offline
post #12 of 17 Old 11-22-2008, 07:01 PM Thread Starter
achipnachair
Well I wish I had read this today before I went and orded the $30 resistor. OH well live and learn. I should have it mid week. I'll let you know how it goes. I am saving that link tho. TYVM for the help.
post #13 of 17 Old 11-22-2008, 09:48 PM
BrunoS
do be aware that from 84-96 the xj uses a 4-spd fan switch in the heater/temp control area that can burn out as well.
in my case, the blower would work on low, med, and not on high or shigh.
i pulled the old switch and got another one from a earlier mopar minivan and replaced my fried one. it also crispied the wiring harness connector to the blower speed switch. IF you smell burning electrical on high blower speed that comes/goes, or have to "tap" the blower speed selector before it works...then you blower switch is going to die like mine... but it's easy to fix.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #14 of 17 Old 11-23-2008, 01:48 AM
mud-dog27
well i litterally just finished fixin mine like an hour or two ago and had same problem like a month ago i onl had high then i had nothing unless i was driving at a decent speed any way my controls obviously worked i could cycle through the diffent modes.....i had no speed control unless manually push started with screw driver...any way the resistor pack is easy to checkhttp://www.geocities.com/chmwatson/F...elink_fix.html
and the blower motor is easy and cheap enough to replace ($57cdn)
http://www.lunghd.com/Tech_Articles/...ower_Motor.htm
i didnt even know i had 4speeds and now it blows better than ever just in time for winter
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #15 of 17 Old 11-23-2008, 11:44 AM
delstele
1997 FSJ Cherokee
Trust me the fan will quit shortly after just working on high been there done it.
delstele is offline
Fan blower only works on high? WTF! ddoffroad XJ Cherokee Technical Forum 37 07-08-2013 08:00 PM
A/C blower only works on high speed. headgasket XJ Cherokee Technical Forum 3 04-13-2009 06:55 PM
Heater fan only works on high speed peterp XJ Cherokee Technical Forum 2 09-02-2008 05:44 AM
Blower Only Works on high Speed dlagrua MJ Comanche Technical Forum 8 07-14-2006 08:51 PM
Heater only works on high? Any reason for this? White-Knight XJ Cherokee Technical Forum 5 04-03-2003 05:01 PM
